10-23-2017, 08:08 PM | #1 |
Rep 1,095
Coolant Leak
I have coolant leak but I cant seem to find where its leaking. I topped off both tanks and two days later they're both empty. There's no coolant marks anywhere and no dripping under the car.
Car doesn't have warranty anymore and I thought it could be the intercooler leaking internally but both reservoirs are empty so idk
2016 M3 Alpine White / Sakhir Orange BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount) Last edited by ///F80M3; 10-23-2017 at 08:17 PM.. |
10-24-2017, 12:05 AM | #3 |
Rep 1,095
Haven't noticed it. Will it smoke on idle?
2016 M3 Alpine White / Sakhir Orange BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount) |
10-24-2017, 11:45 AM | #4 |
Rep 283
Check your top mount charge air cooler/intercooler. You could possibly have a busted intercooler and fins have gone bad inside. Leaks would be internal also. Your car should also be going into limp mode if its getting too hot. I'm tuned and recently had same issue and the intercooler on top of engine went bad and I tried finding the stock one and no one had in the country, ended up upgrading to the CSF intercooler. Its a nice upgrade and probabaly needed one for higher boost with tunes. Last edited by LAKERS333; 10-24-2017 at 11:52 AM.. |
11-05-2017, 05:04 PM | #5 | |
Rep 1,095
11-05-2017, 06:57 PM | #6 |
Rep 1,117
Drives: 2015 BMW M235i
Personally, I would stop driving it and get an oil analysis done asap. Sounds like your head gasket is pooched. If this is the case, you should definitely be able to see white smoke and even the smell of your exhaust on idle will be different.
///F80M3655.00 |
11-06-2017, 01:33 AM | #7 |
Rep 674
The air charge and engine cooling systems are separate. Figure out which is losing coolant first then start your investigation.
I highly, highly doubt your head gasket is blown as mentioned above. If it was, you'd either be mixing coolant with oil or burning coolant in the combustion chamber(s). Both would be very evident and a huge problem. FYI, burnt/hot coolant has a sweet smell to it. Kind of smells like pancake syrup. |
11-06-2017, 08:19 AM | #8 | |
Rep 1,095
11-06-2017, 11:57 PM | #9 | |
Rep 239
Thanks! DMAN |
11-07-2017, 09:03 AM | #10 | ||
Rep 1,095
11-07-2017, 03:55 PM | #11 |
Rep 629
If the intercooler tank keeps loosing coolant, it's likely the intercooler is leaking internally and the coolant is ending up in the combustion chambers. To find out if that is the case, you have to remove the charge air pipe from the 'cold' side of the intercooler and pressure test the cooling system. Once you have pressure on it, check for coolant leaking. You will probably see some residue in the pipe also. This is not common, but it does happen on s55 and b58.
11-07-2017, 10:00 PM | #12 |
Rep 472
I had an intercooler leak and had dealer replace under warranty. Noticed that the reservoir was empty after filling it over and over. Car went into limp mode with drivetrain malfunction warning appearing intermittently. Leak was internal and went into the combustion chamber. Take to dealer ASAP, not good to drive it like this.
Hope this helps |
11-08-2017, 10:17 AM | #13 |
Rep 1,117
DavidGP -- How did they remedy this for you? Isn't the motor pooched at this point?
11-08-2017, 10:30 AM | #14 | |
Rep 472
The way I discovered this was the drivetrane malfunction warning and checking the IC reservoir and noticed it was low. Topped it off and the next day it was low again. Part had to be sent from Germany and car was in the shop 2 weeks waiting. Hope this helps |
11-08-2017, 10:43 AM | #15 | |
Rep 1,117
That's nuts! Glad you got it sorted! Hope this isn't common.
11-08-2017, 11:47 AM | #16 | |
Rep 1,095
11-08-2017, 11:55 AM | #17 |
BimmerPost Supporting Vendor
8273
Rep 18,857
We've seen about a half dozen cars with leaking top-mounted heat exchangers. While not too common, your situation is not an isolated case. Usually, you'll see a Drivetrain fault appear when building boost/heat, with missing coolant in the tank.
Dealer should get this rectified quickly under warranty.
///F80M3655.00 |
11-08-2017, 12:43 PM | #18 | |
Rep 5,056
11-08-2017, 01:04 PM | #19 | |
8273
Rep 18,857
It's not too common, dealer seems to be on top of things in most cases.
11-08-2017, 02:32 PM | #20 | |
Rep 283
This won't be handled under warranty for the OP and many others if tuned. This was the case for me anyways where warranty was voided. If paying out of pocket it might be a good time to just upgrade to CSF intercooler. |
///F80M3655.00 |
11-08-2017, 02:35 PM | #21 |
8273
Rep 18,857
If modded, it depends on the dealer and/or tune being used. Every case is different.
///F80M3655.00 |
11-08-2017, 03:15 PM | #22 |
Rep 1,095
I was considering the CSF but $2k is way too much for me especially since OEM is $600. Hopefully I don't have to replace the OEM intercooler 4 times lol
