10-31-2017, 02:29 PM | #1 |
New Lifetime Replacement Policy
821
Rep 11,738
Now available OPTIMA And NorthStar Performance Batteries
OPTIMA And NorthStar Batteries For Your Vehicle
Make corrosion in your battery a thing of the past with NorthStar and OPTIMA Batteries for your car! Designed to last longer, have a higher power density, and to resist internal grid growth, NorthStar and OPTIMA will be there to start every time. Shouldn't you have confidence in your car's battery? With NorthStar and OPTIMA batteries, corrosion is no longer a problem and you can be sure the power will be there when you turn the key. Thanks to NorthStar's thinner plates with more surface area and lack of additives in the pure lead, these batteries are designed to have faster charging, higher power density, longer life, and virtually no internal grid growth! NorthStar batteries virtually never experience catastrophic failure! Click HERE to shop OPTIMA Car Batteries Click HERE to shop NorthStar Automotive Batteries |
01-08-2018, 11:05 AM | #3 |
821
Rep 11,738
