11-02-2017, 12:18 PM | #1 |
Rep 20
How long a M3 can sit/not be used?
Hi guys,
I just bought 2013 E93 M3 for a weekend car. I am just wondering how long I can let the car sit in garage without starting the engine. Sometimes I am on travelling more than two weeks for my work. *Additional question added* Anyone driving a M3 just for a weekend? How do you guys maintain the car? Do you guys turn on ignition just for a minute or so on the weekdays just to insure the engine against any potential harm? Last edited by chase; 11-02-2017 at 01:18 PM.. |
11-02-2017, 12:23 PM | #2 |
Rep 7,130
Needs to be started and driven hard minimum one time per day. If not engine corrosion and potential rod bearing failure.
11-02-2017, 12:36 PM | #3 |
Rep 233
Mine sits for 4 months in the winter without starting it. You'll be fine.
11-02-2017, 12:38 PM | #4 |
Rep 11,669
^whs
If you aren't already using one, just put a battery tender on it.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
11-02-2017, 12:46 PM | #5 |
Rep 3,450
you will be fine with battery tenderizer.
my car sit like 10 months each year with interval of being started 3 months a time.
"Well, there's a straight-six engine at the front, a manual gearbox in the middle and drive goes to the back. That's Page 1, Chapter 1 from the petrosexual handbook" - JC
11-02-2017, 01:08 PM | #7 |
Rep 20
11-02-2017, 01:11 PM | #8 |
Rep 534
Best not get her panties in a bunch might want to limit to once every two weekends. Just saying.....
11-02-2017, 01:46 PM | #9 | |
Rep 800
11-02-2017, 01:47 PM | #10 |
Rep 800
I assume you have a trickle charger installed, but what else do you do? Do you put stabilizer into a full tank of gas?
11-02-2017, 02:11 PM | #12 |
Rep 386
11-02-2017, 02:23 PM | #14 | |
Rep 880
Drives: 2011 E90 M3, 2019 F150
As for putting it away for the season, put STA-BIL in it and throw a battery tender on it and there shouldn't be any problem. Hang the suspension if you have the proper equipment. It shouldn't really need any special treatment. |
11-02-2017, 03:25 PM | #15 |
Rep 233
11-02-2017, 03:51 PM | #18 |
Rep 1,300
Don’t start the car when it is in storage just for the sake of starting it. You’ll introduce moisture inside the engine that won’t be able to evaporate because the engine won’t get hot enough. The moisture will dilute the oil.
If you have to start the car, make sure you will be able to take it for a drive so the engine can get up to operating temperature to burn off all the moisture. For winter storage, just make sure the gas tank is full so moisture won’t develop and keep the battery charged. You should also do an oil change right before storage as new fresh oil don’t degrade inside the engine from storage but used oil will. If you got used oil in the car before storage then do an oil change when you take it out of storage. Suspension wise it’ll be fine because all modern suspensions are preloaded. Think of how many cars are sitting in dealerships for months before they’re sold and you don’t see them jacking every car up. Tires wise you’re fine as well since run flats won’t develop flat spots. At least not from sitting for a few months. To the OP’s question. If you drive the car every weekend there is nothing to worry about. I own three cars now and two of them, one being the m3 and other is a 16 year old car, both are weekend toys and I’ve yet to encounter any problems from doing all the above. |
MahiC88.00 |
11-02-2017, 03:53 PM | #19 |
Rep 922
Drive mine once a week for last 3 years. Seems fine
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package '11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery) |
11-02-2017, 04:36 PM | #20 | |
Rep 800
xander_g1018.00 |
11-02-2017, 11:58 PM | #22 |
Rep 71
After it's been sitting, give it proper time to warm up so oil can get into any drained passages etc. before you tach it out. (Good for any engine, but extra good for a highly-strung mill.)
