BMW X5 and X6 Forum 2014-Current
      11-06-2017, 08:49 AM   #1
Live4USMC
Live4USMC's Avatar
Drives: 2014 X5 50i M Sport/2016 340XI
Help coding Adaptive LED headlights
Has anyone successfully coded their adaptive LED headlights to function with the anti dazzle function like our european counterparts have? I have the Binmercode app and I’d really like to make this work. I’ve searched and haven’t found anything all that helpful. Thanks in advance.
      11-06-2017, 12:25 PM   #2
Dataready
Dataready's Avatar
Drives: 2023 X5
Originally Posted by Live4USMC View Post
Has anyone successfully coded their adaptive LED headlights to function with the anti dazzle function like our european counterparts have? I have the Binmercode app and IÂ’d really like to make this work. IÂ’ve searched and havenÂ’t found anything all that helpful. Thanks in advance.
My understanding, BimmerCode will NOT do the No Glare High Beam (NGHB). It is strictly through E Sys coding. First you Remove (5AP and 8S4) entries from the FA or vehicle order (VO) then you VO code three ECUs (BDC_BODY, FLE or TSM/LHM, and KAFAS or KAFAS2) depending on which one you have. If you have LED LIGHTS, you have 2 FLE, one right (43) and one left (44). Then you FDL code FLE or LHM. That is all. I have meant to do that for the last month but did not have time.
      11-06-2017, 07:38 PM   #3
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Many have coded it and there is even PDF explaining all changes. It will be a lot of work (110+ modifications) to manually do with Bimmercode. With E-sys, there are Launcher Cheat codes to quickly apply all necessary adjustments.
      11-06-2017, 09:52 PM   #4
boosted43
boosted43's Avatar
Drives: 2017 C43 AMG
2015 BMW 335i  [0.00]
i'm assuming you need to have the lighting package in order to do this or at least the LED headlights as opposed to the xenons.
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
      11-06-2017, 09:58 PM   #5
Almaretto
Almaretto's Avatar
2374
Yes, you need LED Adaptive headlamps (option 552).
xbimmers
