11-18-2017, 06:12 AM | #1 |
Rep 788
Run Flats
I have a set of Pirelli PZero tyres for the summer, and after swapping them for my winters noticed a large screw imbedded into the tread about a third along from the outside. This is on the drivers side front tyre.
Now I'm experiencing various reports on whether this can be plug repaired or new tyre needed? What is the general rule with runflats - are they repairable or is a new tyre needed? Cheers in advance
Old Wheels - X5M50d in Carbon Black
New Wheels - X7M50d in Phytonic Blue |
11-18-2017, 06:24 AM | #2 |
Rep 63
Drives: X5 G05 30D MSports
I had a similar situation few weeks back, mine was found during routine service inspection by BMW service technician. As per what they told me, since it is lodged on the outer side of tyre (and not towards the centre) it needs to be replaced and not repaired (or can't be repaired). They also cautioned me to change both tyres (in my case both rears) to reduce the risk of straining XDrive system (due to different tire tread depth and as a result different circumference. I ended up changing both... after all tyre is much cheaper to replace than to deal with drivetrain related faults.
11-18-2017, 08:58 AM | #3 |
Rep 538
Discount tire will repair, if it's repairable, with a patch from the inside. I find them to be the best for flat repair because they will repair, if it falls into guidelines for repair. In my experience, most tire "repair" shops will just say "not repairable" without regard for where the hole is located.
11-18-2017, 12:19 PM | #4 |
Rep 26
Found a nail in a front tyre during the MOT last year. It passed the MOT again this year (same nail with about 3000 miles on it) and the BMW tech told me to leave it. Either it’s not all the way through or it’s doing a good job plugging the hole.
11-18-2017, 09:32 PM | #5 |
Rep 841
Bad news. Pirelli runflats are not repairable. That is Pirelli’s policy, you can search it on the web. Had the same thing happen and Discount refused to repair it due to the policy. Other runflat brands can be repaired. I forget which others cannot.
You may get lucky and find someone who will fix it. Pirelli does have a replacement policy for this situation and depending on your miles on the tires they may replace it. Again, see their website. |
11-18-2017, 11:20 PM | #6 | |
Rep 2,388
However, what you are saying is that Pirelli RFT can't be repaired even if screw is in the thread? I understand it may be some weird Pirelli policy, but I doubt Pirelli RFTs are made any different than any other RFT brand. I mean this is not a rocket science - it's just a reinforced metal mesh sidewall. I highly doubt Pirelli has some extraterrestrial tire tech lol Last edited by DuSh; 11-18-2017 at 11:28 PM.. |
11-19-2017, 06:18 AM | #7 |
Rep 841
I’m not saying you can’t try to repair them, just saying Pirelli won’t let authorized shops do it. First the good news - the road hazard warranty Pirelli includes free
"If a Run Flat tire becomes unserviceable due to workmanship or material irregularities or road hazard injury during the initial warranty period, the tire will be replaced to the owner at no charge. The initial warranty period lasts one year from the date of original retail purchase (purchase receipt required) or within the first 2/32" of original tread, whichever occurs first. After the initial warranty period, if a Run Flat tire becomes unserviceable due to workmanship and material irregularities or road hazard injury, the owner must pay the cost for a comparable new Pirelli brand or PTNA private brand replacement tire on a pro-rated basis.” Here is the list of run flat brands and their repair policies. https://www.tirerack.com/tires/tiret...jsp?techid=226 |
DuSh2113.50 |
11-19-2017, 10:48 AM | #8 | |
Rep 788
11-19-2017, 10:52 AM | #9 | |
Rep 788
11-19-2017, 10:55 AM | #10 |
Rep 788
This is the culprit!
Not wanting to have to change for a new tyre I'm hoping a repair will do?
11-19-2017, 02:39 PM | #12 |
Rep 18
As others have said you can fix this. I had an Exacto blade lodged in my P Zero RFTs and my local tire shop fixed it with a patch from the inside. It was a quick cheap fix that saved me hundreds of dollars as I was outside of the Pirelli warranty period.
11-20-2017, 12:10 AM | #13 | ||||
Rep 63
I had around 4mm+ left on both them. I did check with one more BMW service centre and their advice was identical I saw the pic posted by you, mine was in similar position but on a far side rear tyre. I am not sure if in UK we have anyone who can repair runflats. If you do find anyone it will be a good reference to have. Best of luck |
11-20-2017, 04:09 AM | #14 |
Rep 1,417
1st yr replacement in Canada, dealer replaced if you inform them.
I replaced RF at dealer, they specify on invoice, client declined new tire and no warranty on repair. My indy plugged another tire. Yours should be pluggable. Where warranty applies, one could consider Pirelli. I believe most don't, with most opting nonRF, no warranty. |
11-26-2017, 11:41 AM | #16 |
Rep 1,340
11-26-2017, 12:06 PM | #17 |
Rep 177
