05-24-2008, 01:57 PM | #1 |
Doctor Awesome!
11
Rep 194
No doubt this is a dumb question, but...
How possible do you think it is that I could tow a small sailboat behind the M3?
The entire set-up, boat and trailer weighs less than 1K lbs, and probably less than 900Lbs. The dealer also said no, no chance, but I also suspect that they have no idea either. I should also add that it will not be towed very far, or very often. |
05-24-2008, 02:04 PM | #2 |
Rep 6,007
you should just strap the boat to the roof instead with a long rope going through the drivers side window and back out the passenger window. When you start driving fast reach you hand out the window to hold on to it to make sure it doesn't blow off. This technique usually works pretty good.
05-24-2008, 02:06 PM | #3 | |
Doctor Awesome!
11
Rep 194
05-24-2008, 03:27 PM | #6 |
Rep 471
the manual only says that the weight on the hitch must be considered when loading the car, ie, do not exceed maximum...
it has the power and gearing...the issue will be finding a hitch and hooking up the required lighting... |
05-24-2008, 03:50 PM | #7 | |
Doctor Awesome!
11
Rep 194
I had not considered the lighting either. I guess some investigation is required to figure out if that will work. |
05-24-2008, 04:14 PM | #9 |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
It should be possible. You would be amazed at the things I've seen people tow in Germany with a small car. They generally don't do pickup trucks there, so it's not unusual at all see hitches on small and high performance cars, as they use small utility trailers instead of pickups. Sorry I can't help you with any specific info as far as hitch installation, but I would think that 900 pounds would be no problem.
05-24-2008, 04:35 PM | #10 | |
Rep 13,019
I bet that there is a hitch kit in Europe for the E9x... |
05-24-2008, 04:38 PM | #11 | |
Doctor Awesome!
11
Rep 194
05-24-2008, 04:39 PM | #12 | |
Doctor Awesome!
11
Rep 194
For reference, here is the sailboat I have coming. http://www.laserperformance.com/main...443&Itemid=302 The Stratos Keel. |
05-24-2008, 05:28 PM | #14 |
Moderator / European Editor
1547
Rep 6,754
05-24-2008, 05:41 PM | #15 | |
Rep 3,592
'08 E92 M3 6MT | IB | FR | RAC RG63's | VRS Ti Exhaust | Fabspeed HFC & Xpipe '09 X5 35d SG/SB '11 X3 28i AW/CN/FW (wife's car |
05-24-2008, 07:12 PM | #16 | |
Doctor Awesome!
11
Rep 194
05-25-2008, 02:27 AM | #17 |
Rep 10,407
05-25-2008, 08:47 AM | #19 |
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
Seriously, buy a cheap 4x4 to tow your sailboat. It will also serve as a good winter vehicle too.
I can't see how you could attach a hitch without modifying the rear bumper bodywork.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
05-25-2008, 10:45 AM | #20 |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
I have friends that justified buying enormous tow vehicles just to drag two motorcycles or PWCs. I used to regularly tow two sportbikes on an open trailer with my 325i, no problems whatsoever.
The rear underside of this car is pretty crammed up with mufflers, what did E46 M3 people use? I'm interested. |
05-25-2008, 11:37 AM | #21 | |
Rep 4,128
Drives: M235i & G30 540i
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
05-25-2008, 11:47 AM | #22 |
pull my finger to get your kinder® surprise
148
Rep 10,455
quote of the day
