BMW X5 and X6 Forum 2014-Current
      12-27-2017, 07:04 PM   #1
ministar
Serbia
Drives: X5 F15 2017
Speed limit info
Proud owner of X5 F15 X25D M package MY2017
I have problems with speed limit info, for some reason HUD and control panel does not "read/display" speed limit info from signs. I we searched entire forum but i didn't find this issues with X5. I have connected drive camera with line tracking, front collision warning, pedestrian alert, HBA and also i have navigation pro with touch screen and iDrive 5. How can i activate this feature or fix issue?
Thanks in advance!
      12-28-2017, 02:09 AM   #2
turboawd
Drives: 2015 X5 35i
isnt there an option in the settings on the idrive under hud options?
      12-28-2017, 07:14 AM   #3
ministar
Serbia
Drives: X5 F15 2017
Yes, there is option to enable on HUD or display, but i see only icon without traffic limit like this:
https://i.ytimg.com/vi/7bZinfFQZt8/maxresdefault.jpg
      12-28-2017, 04:56 PM   #4
turboawd
Drives: 2015 X5 35i
the connected drive camera reads the speed limit signs as you drive. is your camera working ok? obstructed?
      12-28-2017, 05:29 PM   #5
ministar
Serbia
Drives: X5 F15 2017
As i know, camera working fine, since HBA feature using camera for incoming cars and HBA working fine... i have issue only with signs... I am wondering is there a option to check this feature over coding or etc...
      12-28-2017, 05:37 PM   #6
retx
Drives: '18 F15 40e
It seems the camera is reading speed limit info with the white-color background much better than the one with other colors (yellow, blue, etc.).
      12-28-2017, 05:42 PM   #7
CatalinP
Drives: BMW X5 F15 2014 3.0xd
The problem is the navigation map. Drive outside Serbia and it will work.
      12-28-2017, 05:42 PM   #8
turboawd
Drives: 2015 X5 35i
do the speed limit signs in your country look like what is shown on your display?
was your x5 originally bought in serbia?
      12-28-2017, 05:49 PM   #9
barcelona
barcelona's Avatar
Drives: X
Since you have both HUD and Speed limit info/SLI .
If all is well, you should be able to see SLI on both Instrument Cluster and Windshield/HUD. I always find HUD is best as it is in your line of vision as you drive.
You should see be able to enable this through settings. Let me check my x6 tomorrow.
      12-28-2017, 05:52 PM   #10
CatalinP
There is nothing wrong with the camera, hud, settings or signs.
The navigation map for Serbia does not have speed limit information, therefore the system will not work, even if the camera reads the signs.
If he will drive his car to Germany, the speed limit info will work fine.
Jenya B144.00
barcelona271.00
      12-28-2017, 06:11 PM   #11
ministar
Serbia
Drives: X5 F15 2017
turboawd i ordered car in Germany
CatalinP Thanks for answers i will check with dealer tomorrow..
Also is there a way to update maps
Since is very funny that cheap navigation systems like iGo, Here have those data and bmw don't
barcelona271.00
      01-20-2018, 06:23 AM   #12
Bambazonke
Bambazonke's Avatar
Australia
212
Drives: 2017 X5 & 2020 X5
  [0.00]
SLI also not working in Australia
I also have the same issue here in Australia where SLI does not work. BMW Australia deliberately removed it from the X5 model range here sometime ago due to litigation reasons. I am now trying to reactivate it in mine as one forum member has just bought a new G series X3 here in Australia, and has confirmed he has the function working. I have also updated my maps to the same as what he has. I also have all the appropriate hardware plus more installed, so it's just a matter of coding it back
I have managed to code the NBT2 unit to display the option to turn it on in both the instrument display and HUD but sadly it did not work. I don't even get the blank sign as seen in the OP's link to the pic of the instrument panel
Is there anybody out there with a 2016/17 X5 with SLI working that does E sys coding that can send me a copy ncd files of their Kombi and Kafas2 modules so I can compare them using Tokenmaster's Software Tools. Ideally it would be good if I could get an EU ROW model as my experience with VAG autos is the US/Canadian models differ somewhat compared to the ROW. However something is better than nothing
Please PM your email address so I can send you mine and copies of my ncd files for your perusal and verification.
I have also had a look at my 2016 Garmin maps of Australia and they all have the speed data then so I don't believe it's a map data issue
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
      04-30-2018, 01:43 PM   #13
drakshi
Drives: BMW X5 (F15)
Thanks in advance!
Hi,
With my X5 F15 I have tested the speed limit info in the folowing countries:
In Germany, Austria, Croatia and Romania works fine.
In Serbia, BiH, Macedonia and Bulgaria does not work.
I bought the newest map updates and installed but still doesn’t work in mentioned countries.
I’m not sure it depends on maps, if I am not wrong camera reads signs and all the maps should contain speed limits because it should be the main parameter how the navigation calculates trip time estimation for choosed destination.
Could you please share your expirience with RTTI - real time traffic information in Serbia or other Balcan countries. I bought RTTI service but it worked fine only when I was in Austria and Germany.
Thanks!
      04-30-2018, 01:58 PM   #14
sj22
Drives: 14 F15 50I
I believe default speed data is provided by maps, and if the kafas2 camera does read a sign, it will update and override the display from the sign. So if the maps don't have the SLI, this will not work.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors
Past: 2013 750i xdrive, 2008 535xi
CatalinP591.00
      05-01-2018, 03:26 AM   #15
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
buy this model and code for SLI. I believe another guy from Australia made it worked!
https://www.ebay.com/itm/Speed-Limit...19.m1438.l2649
Read this thread for more info! https://f30.bimmerpost.com/forums/sh....php?t=1203393
      02-28-2022, 11:13 AM   #16
baiibyy
Bosnia and Herzegovina
Drives: X6 F16
Thanks in advance!
Did anyone know how to solve this? Someone says that you can code something so it works in Bosnia/Serbia for example? I have also 2021-3 Nav Map, ID5 etc etc, when I go to Croatia SLI works perfectly. When I come back to Bosnia it doesn't work, is there anything I can code so camera reads signs here too or to take info from Navigation MAP? I read somewhere from phone, on some another forum when I was traveling that people code something and it's working, but now I was searching 2 days and can't find that thread. I am up to pay/donate if someone help me fix that. Thanks in advance and sorry about not perfect english
And yes, I dont wanna upgrade some Chinese SLI Emulator
Last edited by baiibyy; 02-28-2022 at 11:14 AM.. Reason: Forget to write about Chinese adapters
      03-01-2022, 08:09 PM   #17
Bambazonke
Bambazonke's Avatar
Australia
212
  [0.00]
Thanks in advance!
I ended up getting an FSC code from a dealer to get it to work it was expensive and I subsequently found a thread on the forum where there is one member that can supply it at a much lower cost
      03-02-2022, 04:08 AM   #18
baiibyy
Drives: X6 F16
My car already has a 7E SLI FSC Code issued to it and Option Code 8TH Road sign detection but still doesnt work in Bosnia/Serbia, only Croatia, Germany, EU etc
      03-03-2022, 06:21 AM   #19
Wojti_
Drives: BMW F11, G30
necessary to code it, pm me we can test on car
      03-03-2022, 06:22 AM   #20
Wojti_
I can help to order fsc
      03-05-2022, 11:10 AM   #21
baiibyy
Drives: X6 F16
Originally Posted by Siki78 View Post
Yes you can just change this line in kafas2
COUNTRY_SLINPI_MODE
wert=00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00
This is working! Now my SLI works perfect in Bosnia, Serbia, anywhere. Many thanks to Siki78 who helped me!
      05-29-2023, 11:57 AM   #22
Vagelis76
Drives: BMW F15 M50d
My car is one F15 m50d with driving assistant plus and kafas2 camera but I can not code the speed limit info .
I have made all the coding with bimmer code software but the only thing I see in cluster and hud is “ - - - “
Can anyone help me ??
Thank you
xbimmers
