01-26-2018, 11:46 AM | #1 |
Rep 937
Thinking of a 2015/2016 X5
Guys, I need your input. I have an F10, but could use the extra cargo room that the F15 would add. What options are must haves in your opinion? Just starting my research so I really need some items to start my search.
01-26-2018, 12:28 PM | #2 |
Rep 846
M-Sport with Adaptive Suspension at a minimum.
Since the ground clearance is soo high it's a little harder to see the curbs so surround view cameras are a good option as well.
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
01-26-2018, 02:01 PM | #4 |
Rep 1,066
Drives: 2015 X5 50i M Sport
Easier to find fully loaded X5 50i than fully loaded 35i. Good luck!
2019 Cayenne Turbo
Gone but not forgotten: 2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport |
01-26-2018, 02:53 PM | #5 |
Rep 1,180
HUD, Heated steering wheel, 20s, MSport package, comfort access, driver assistant, rear view camera (I think it wasn't standard on those years).
01-26-2018, 11:34 PM | #7 |
Rep 2,388
Depends what you want
Engine I would start with deciding what engine you want V8 or I6? This is a major difference from the beginning (with V8 n63tu - you'll get V8 sound and power, lots of it, but worst MPG). With I6 you have choice of n55 (cheaper and more reliable) or n57 (diesel - hence best MPG) Exterior 1. Next choice is exterior: M Sport vs everything else. M Sport is a must IF you care for appearance. 2. 20 inch rims are a must too. Please don't buy x5 with 19's - they look so small, unless you have a plan to put 21 or 22 aftermarket rims and keep 19s for winter set 3. LED headlights are preferable, they look cool and have a bit more functionality (comes in Lighting Package if I'm not mistaken) Interior 1. Comfort seats (or aka multicontour seats) are preferable as they are most comfortable for long drives 2. M Sport steering wheel (comes with M Sport package if you got one, hence M Sport package is desirable to begin with) 3. 3rd row seating - this is purely a need based choice - you either need them or not. You can't retrofit them, so if you need them - you have to buy one that has them in the first place 4. 4 way climate control (including rear heated seats etc) - I think anyone with family can use it in cold climate Tech 1. HUD (thing that projects dash info to windshield) - I have one and I got used to it, it's good thing to have 2. Comfort access - very convenient, I can't live without it now, I'm so used to it now (also comes with Premium Package if I'm not mistaken) 3. Driver assistant package+ (I think it's called a bit differently) that includes 360 view (including rear view of course), line control, blind spot warning and active cruise control (ACC) Suspension 1. Get adaptive suspension - it has 4 modes and dampening of shocks is changed electronically from soft to hard - must have imho 2. DHP (Dynamic Handling Package) - this is RARE to find in used x5s, but if you can get it - it's golden! It makes 5300lbs x5 handle like a 3500lbs sedan. The DHP tech is amazing and includes active stabilizer bars, torque vectoring and so on This is a start list, there are too many other options, I only tried to put major ones that you may regret not having - and I'm sure I still forgot one or two |
Stev_chu108.00 |
01-27-2018, 12:48 PM | #8 |
Rep 1,340
Here are a couple of almost fully loaded CPOs, msport with dhp:
https://www.bmwofnashville.com/certi...eb19212749.htm https://www.herbchambersbmw.com/cert...b5c921cf1e.htm |
01-29-2018, 05:53 AM | #9 | |
Addicted to Speed.
714
Rep 2,375
2017 991.2s
2015 F15 35i 2017 Macan gts |
