02-13-2018, 06:57 AM | #1 |
Rep 405
Alignment Issue/Question - Wheel out of spec
Looking for some help/direction from the suspension gurus around here.
Took the E92 in for regular alignment maintenance and all was OK except for passenger front at -2.7. Tech didn't see anything out of the norm and couldn't explain the issue. Mods: - Ohlins R&T - GroundControl Camber Plates- Street Per GC instructions the plates are set to the 'CL' mark meaning no additional camber is being introduced. Centering Pin is in place and installed correctly. I know the answer can be many items but I was hoping to hear about the top 5 causes of why this could happen and how I should go about correcting the issue. |
02-13-2018, 10:56 PM | #3 |
Rep 1,055
Alignment sensors not properly aligned or your dampners aren't symmetrically seated into the knuckles would be my guess... this is in addition to variance in corner balance of the car due to the weight not being equally distributed (which also causes camber variation).
Many people find that they can't get height the same from side to side, myself included, and the reasons above are my suspicion. Additionally, in order to get my alignment's the same, my camber plates are not in the same position vs one another but they aren't significantly different. Last edited by M43S7RO; 02-14-2018 at 07:15 AM.. |
02-14-2018, 11:27 AM | #4 |
Rep 468
I've actually had this happen to in the past. Had the car at the dealer multiple times, no issues found. I think its normal? It hasn't happened again in over a year so no clue.
2015 F80 M3 - Yas Blue, Silverstone Full., Bilstein B6 shocks, Eibach Springs, Full M Performance Carbon Add-ons, Titan 7 Wheels.
(past) 2012 E92 M3 - Melbourne Red - Eibach Springs/AG M359/ performance spoiler/ performance splitters/10mm spacers, Macht Schnell Test Pipes, Alpine Stage 2 Tune. |
02-14-2018, 12:34 PM | #5 | |
Rep 405
the dealers answers was honest; short of just replacing parts ad-hoc we dont 'see' anything wrong but they the alignment measurements are in-fact off. |
02-15-2018, 12:08 PM | #6 |
Rep 1,326
I have no camber plates and my front passenger camber is 0.3 degrees (-2.5) more than the driver's side (-2.2), center pins removed and struts pushed all the way in for max camber. Never figured out why it was.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
02-21-2018, 08:39 AM | #7 |
Rep 8,077
Drives: 11 E90 M3 Individual
Those alignment specs don't account for the weight of the driver although I highly doubt that it would cause a -1.0 degree change in camber.
I'd just make sure all of the bolts and nuts are tight. Check the strut tower to make sure the sheet metal isn't deformed. If nothing is bent, nothing to worry about.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
