02-19-2018, 11:37 AM | #1 |
Rep 482
Help diagnose steering wheel shake
Hi all,
I've been dealing with steering wheel shake for quite some time now and it is extremely frustrating. I am experiencing shake while driving and under braking. Mostly noticeable around 70+ mph. Almost always noticeable under braking. Especially if I am coming around a corner to a stop, it is more severe under braking. I am running 12.5mm Macht Schnell spacers all the way around on ZCP wheels.
Any advice at all would be greatly appreciated!
2011 E92 M3 | ZCP | Active Autowerke-headers back | Brembo 380mm f/r | OSS Headlights | Full Gloss Carbon Interior | AW/FR |
IG: loganflack_e92 |
02-19-2018, 12:11 PM | #2 |
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
I had the same issue with my previous e46 M3. It turned out to be worn suspension bushings. Once replaced the symptoms completely disappeared. The bushings do wear out, and are relatively easy to replace. This would be the first place I would look now that you know that your wheels are aligned and balanced.
DreamTime864.50 |
02-19-2018, 12:13 PM | #3 |
Rep 1,171
May not be possible with brembos clearance but my first step would be to remove the spacers and drive it to check for vibrations
02-19-2018, 02:18 PM | #4 |
Rep 356
Steering wheel vibration I have experienced has been from bad front lower control arms, another time brake pad deposits on the rotors and once due to feathering and cupping of my tires from track driving.
02-19-2018, 03:38 PM | #5 | |
Rep 536
I had the very same symptoms with a Lexus i use to drive. I replaced the control arm bushings and the car drove like it was new. |
02-21-2018, 07:48 AM | #7 |
Rep 331
Try take off the wheel spacers and see how it goes.
I encountered similar issues when I had MS spacers on my ZCP wheels in all corners. They might work fine in F80/F82 because of actual disconnection of electric steering. But in our car, they are trash.
Past: E82 135i Crimson Red | MPE | MHD Stage1+ | Dinan Camber Plate | LCI Blackline | Bavsound stage 1 | KW Coilover V2 |
Past: E93 M3 Vert Alpine White | Remus Sport Exhaust | Past: F82 Yas Marina Blue Civic M4| MPE V2 | DP | BM3 | Apex FL-5 | MP Part(s) | Current: F87 M2 Competition Long Beach Blue | Completely Stock | |
02-21-2018, 07:54 AM | #8 |
Rep 482
I will be removing the spacers today and will report back! Hoping this is the cause. Makes the car look great, but I much prefer a better driving experience.
02-21-2018, 08:19 AM | #9 |
Rep 298
Not sure how your roads are, i had wheel wobble at 70+ due to bent wheels (potholes). Had it corrected, ran like new. Thats one possibility.
02-21-2018, 08:55 AM | #10 |
Rep 12,736
Lose the spacers.
Did you track the car? Pad deposits might also be a problem, even with a 380mm kit if you used street pads.
Instagram; @roastbeefmike
02-21-2018, 09:58 AM | #12 |
Rep 364
Do you guys mind sharing your mileage with resolutions to issues? Helps give a reference point to those reviewing and learning from the thread.
2011.75 E90 M3 ZCP, 6sp, Interlagos Blue
2008 E93 M3, DCT, Melbourne Red 2007 E91 328xi Touring Wagon, Jet Black 2007 Audi B7 S4, 6sp, Sprint Blue Sold: E70 X5M, E46 M3 6sp cabriolet, E46 M3 SMG |
02-21-2018, 11:23 AM | #13 |
Rep 994
I ran into this issue around the 140k mile mark and I drove it this way for about 2k miles. I thought it was a wheel bearing at first because of the play in my front wheel. The new wheel bearing seemed to help a little but the issue was still there. After that I decided to get under the car and had someone else wiggle the front wheel, I could see the play in the lower control arm bushing where it met the wheel hub. I decided to replace the whole arm instead of just the bushing. Completely solved the issue. I will say that I believe that I left it untreated long enough for it to cause my wheel bearing to go bad. So I wouldn't sleep on it unless you want to replace both.
ghostofsenna129.50 roastbeef11591.50 |
02-21-2018, 07:11 PM | #14 | |
Rep 356
03-01-2018, 05:59 PM | #16 |
Rep 342
I'm getting similar wheel shake around 70mph but nothing with braking. I'm also on zcp suspension/rims with front/rear spacers.
Getting a slightly bent front rim fixed next week and hoping this will resolve. Will report back! |
03-06-2018, 03:11 AM | #17 |
Rep 1
I experienced same issue two weeks ago,so I tried to move wheel spacers.Then no shaking.
Buy my friend got a good deal from this site (www.hexautoparts.com) for a set of 4 pieces wheel spacers ,installed them,his car runs well,without any problem. Not sure why. Is that possible some wheel spacers are good but some not ? |
03-08-2018, 09:03 PM | #18 |
Rep 442
It is your spacers. Even when you check that take off and put back on it is the spacers.
I had the vibration at like 80mph+, I took the spacers off, used some scotch brite then put them back on, still vibrated. Then I did it again and it did not vibrate. It is like they need to fit perfectly in a certain way and there will be no vibration. |
03-11-2018, 02:46 PM | #19 |
Rep 1,171
07-23-2018, 08:39 AM | #20 |
Rep 482
I took off the front and rear spacers and am unfortunately still experiencing steering while vibration. Still on the hunt for the culprit..
07-23-2018, 08:52 AM | #21 |
Rep 769
I would take the car to your trusted tire shop and watch each tire spin on the balancing machine. Even the slightest bend will give you a lot of feedback. Worth it to check before you spend money on suspension parts.
