03-09-2018, 03:30 AM | #1 |
Rep 742
I have to smog my car and I cannot pass the obd readiness test. I was fully catless with a stage 2 tune but earlier today switched my stock x pipe on and flashed to stock tune. After I did that all, I looked up the BMW drive cycle guide and followed it. There was a bit of traffic during that time but I still tried to do some of the tests. I have Bmw Carly and android Torque app to let me know if I'm passing the readiness tests as well. I didn't pass, I drove home and figured that I'll just let the car sit for 5-6 hours and try again at night with no traffic. I just got back home after 2 hours of driving. Still didn't pass on the same 3 monitors:
Catalyst Incomplete Secondary Air Incomplete O2 Sensor Incomplete These are the only 3 I'm failing. I did everything perfectly and still can't seem to get these to pass. Probably put 80 miles on the car tonight. Anyone have any recommendations? I need to smog ASAP as my registration is expired. Gonna attempt again in the morning, I know the drive cycle mentions that the car needs to cold start but after letting the car sit for about 5 hours earlier today I figured that was enough. These were my steps: Turn car on and let it idle for 3 minutes Speed up to 20-30 mph for 3-4 minutes Speed up to 40-60 mph for 15-20 minutes Decelerate to stop, leave car in gear and let idle for 5 minutes (Made sure to keep radio and A/C or Heater on the entire time) |
03-09-2018, 07:31 AM | #2 |
Rep 45
I had a similar issue on an e46 ZHP a few years back and the dealer suggested that I disconnect the negative battery cable for about 30 minutes. I'm not sure if something was hung up but that solved the problem and the car passed inspection.
03-09-2018, 11:14 AM | #5 |
Rep 801
If you throttle up it stops the tests. Porsche 993s are really hard to get to set the readiness monitors, and I typically have to get on the highway and just do 45-50mph for 10-20 minutes to finish it. It is incredibly unpleasant to drive down the highway below the speed limit in a 993TT.
To get secondary air set, you need to start the car stone cold and literally just sit there for a while. I recommend waiting a couple minutes past when you hear it turn off.
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
03-09-2018, 11:16 AM | #6 |
Rep 801
With that many monitors incomplete, he can't pass anywhere that tests.
03-09-2018, 12:39 PM | #7 |
Rep 742
I believe that just resets the ecu and all monitors. I was thinking about doing a reset as well but idk if the monitors are close to being passed with the driving I did yesterday. Gonna give it another shot today and if it still doesn't pass just reset it
03-09-2018, 03:49 PM | #8 |
Rep 742
Edit 2:
Started the car up and let it idle for 6 minutes this morning. Went through some stop and go traffic on the way to the coast and did the 20-30 mph for 4 minutes and then hopped on the freeway and kept it at 55 mph for 20 minutes then came to a stop and idle for 6 minutes in gear. Still failing on same 3 Catalyst incomplete 02 Sensor Incomplete Secondary air incomplete These cars are a pain in the ass. Any recommendations? I reset the ecu before I left which I believe reset the monitors. Thinking of unplugging the negative cable from the battery for 20 minutes |
03-09-2018, 05:27 PM | #9 |
Rep 742
Few questions, I'm going to take the car out again tonight gonna let the car sit for around 8 hours since a few shops said the car needs to be really cold for the cold start.
Can I leave my car on cruise control? 2 smog shops that do a lot of bmw's say to leave it on cruise control, that's how they do it. They also said to just drive like 30 minutes straight at 55 mph. |
03-10-2018, 01:06 AM | #10 |
Güdentyte
1174
Rep 1,210
Never disconnect the battery when it’s right around the time to get the car smog tested. Not only it resets the monitors, it also resets the drive cycle.
I Followed the drive cycle from the link below. Look at page 2 and you have to be very precise and stay below 3000 rpm. There is a canyon back road about half a mile from my house so I made sure to drive around my neighborhood at low speeds first and hit the canyon at a steady 50mph for 15min. I had to do this routine at least 3x within a few days apart and then hit the freeway at a steady 80mph. It took me a total of 250-300 miles to get all the monitors check green for OBD readiness again. Having the Carly app helps a lot when you need to check the monitor status on the fly. http://www.europeantransmissions.com...0Procedure.pdf Good luck.
CURRENT - 991 GT3 | Future Classic 1M | Model 3 | T4R TRD Pro Lime Rush
SOLD - MB M2 CS | SMB F80 M3 CS | E90 M3 | E90 335i | E46 M3 Vert | E39 M5 | E34 525i |
03-10-2018, 11:09 AM | #11 |
Rep 829
I don't understand why you'd go back to stock? Assuming your stage II tune kept all systems in "ready" status, you should pass as no sniffer is required in CA on modern cars. As long as the smog computer can plug into your DME and think everything is "normal" you're good to go.
The only chance of you failing would be visual. Is that why you went back to stock? In my experience most techs don't really A) look that closely and/or B) don't really know what to look for - if they see two resonators under that car they assume cats. On the other hand, going back to stock should not be resulting in your current issues, so not sure what's going on other than drive cycles. But, again, in my experience, it takes only a few short drives/miles to set everything back to normal. Certainly not days and hundreds of miles. |
M3LISSA809.50 |
03-10-2018, 01:53 PM | #12 | |
Rep 742
03-12-2018, 10:19 AM | #13 | |
Rep 801
09-07-2018, 08:45 PM | #14 |
Rep 15
Any update on this. I am having the same issue and need to pass emissions this month. Same 3 non-ready items.
09 E92 6 Spd m/t w/ ESS 625 Kit and full ESS Exhaust. 09 Turbo'd HD Muscle
09-07-2018, 08:48 PM | #15 |
Rep 742
Yes it turns out my ambient temperature sensor was broken. Ambient temp sensor detects temperature outside so I didn't think it has any correlation to the emissions monitor and it doesn't throw a hard CEL or SES light. Changed it and within 5 minutes the monitors all turned green. Scan the car and see if you have a code stored in the motor control unit, if you do fix it because that's most likely causing the monitors not to turn on
09-11-2018, 08:24 PM | #16 |
Rep 15
Awesome thanks. I cleared all the codes recently and aren't showing any now. Do you recall what code popped up for the temperature sensor?
09-12-2018, 03:08 PM | #19 |
Rep 980
Hard to change? I recently went back to stock too, and didn't flash my tune back to stock yet. Which reminds me.... I need to. Now I'm freaking out worried about this issue as well. Ugh.... pray for us. I love my car, but I really hate this part.
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
///M Power-Belgium64252.50 |
09-12-2018, 03:15 PM | #20 |
Rep 24,867
Mel ..I will pray for you !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
09-12-2018, 03:37 PM | #21 | |
Rep 742
As for the ambient temperature sensor, it's very simple. You have to remove the driver side fender liner and pull you'll see the black plug there. |
09-12-2018, 04:52 PM | #22 |
Rep 3,274
There's a really simple solution... don't add features to your car that prevent it from passing SMOG, which isn't that hard. Really easy in fact.
