03-28-2018, 01:06 PM | #1 |
Rep 127
Hre Wheelfitment!
Hey guys I just put my deposit down for HRE's I just have a few questions about the offsets. I plan on running Michelin PSS
255/35/19's F 295/30/19 R Will I rub with 19x9.5 Et 22 19x10.5 Et 23 I believe it'll be be perfect without any issues but just want your guys OP. Thanks! |
03-28-2018, 03:20 PM | #2 |
Rep 1,326
you'll be fine, might need to run a little more camber in the rear to avoid rubbing. et25 would allow minimal camber with 295/30/19 PSS.
i'd go 275/30/19 in the front. square sidewalls and you keep the natural stagger.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
kawstik607.50 |
03-28-2018, 08:29 PM | #5 |
Rep 960
I had the same wheel sizes but both +22 offset. Same rear tire size and a 265 front tire. On zcp suspensión and with stock camber, it would only slightly rub the rear on significant dips/bumps. Otherwise no issues. With edc set to sport it never rubbed at all.
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10 |
03-28-2018, 08:40 PM | #6 |
Rep 257
I'm running a similar set-up. I believe my front has a 5mm spacer though. Rubs a tiny bit
19x9 et 25, 255/35/19 - Michelin PSS 19x10.5 et 26, 295/30/19 - Michelin PSS DAN_3842 by Dan Lee, on Flickr DAN_3861 by Dan Lee, on Flickr DAN_3818 by Dan Lee, on Flickr Last edited by O2ShootTheJ; 03-30-2018 at 10:04 AM.. |
03-28-2018, 11:46 PM | #7 |
Rep 1,236
The rear is pretty aggressive offset for 295. Depending on your ride height the rear might hit the outside of the fender, not just the inside liner. I used to run 19x10.5 et23 with PSS 295/30 and burned off some paint, but my car is also lowered.
Fronts you should do 275/30. |
03-29-2018, 08:18 AM | #8 | |
Rep 127
03-29-2018, 04:26 PM | #9 |
Rep 479
you could have also went GTS spec, 255 front 285 rear
Current Car List
2020 F87 M2 CS - Hockenheim Silver 2020 F97 X3M- Phytonic Blue |
03-29-2018, 04:47 PM | #10 |
Rep 1,236
03-29-2018, 04:48 PM | #11 |
Rep 1,326
why don't you request a change to the rear offset? or are these off the shelf flow forged wheels?
03-29-2018, 05:08 PM | #13 |
Rep 127
03-29-2018, 05:09 PM | #14 |
Rep 127
