04-14-2018, 08:30 PM | #1 |
Rep 384
'09 e90 M3, is there a way to add Bluetooth for audio?
I really want a 2011.5 but I came across a 2009 that is a really good deal that has virtually everything on it except for a few key features like apps and Bluetooth for streaming music. Is there any way to do a software upgrade? Sorry I am completely ignorant when it comes to this.
04-14-2018, 09:08 PM | #4 |
Rep 1,694
Fairly simple install in the boot, they then remote code it so you will need a laptop with an internet connection. The coding takes about 30 minutes. They have a list of installers they can recommend depending on where you live. As for cost, try googling 'E90 M3 combox bimmertech'...
04-14-2018, 10:22 PM | #6 |
F15 daddymobile
2355
Rep 3,520
I use a tune2air for bluetooth music and it works well.
MachinesWithSouls4846.00 |
04-15-2018, 05:35 AM | #8 |
Rep 65
Drives: 2008 e93 M3
Coodio
Coodio Bluetooth on amazon. $6.98. I have it, works well. Does use aux input so audio is ...ok.
04-15-2018, 07:05 AM | #10 |
Rep 65
Drives: 2008 e93 M3
Avin makes a decent looking one...unfortunately still uses aux input?
04-15-2018, 08:48 AM | #11 |
Rep 335
I also use the tune2air on my 09. It's sufficient and much cheaper than a combox retrofit.
https://www.amazon.com/dp/B00R3ABHXY/ |
04-15-2018, 11:37 AM | #12 | |
Rep 384
04-15-2018, 01:54 PM | #13 | ||
Derbo Tuning
3612
Rep 3,028
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
04-16-2018, 07:37 PM | #15 |
Rep 270
Drives: Red
Will eventually do the avin but have been using a tune2air for a while as well and it works great. Haven't figured out how to get calls to route through it though.
04-16-2018, 10:10 PM | #17 |
Rep 438
I've used Blackberry Music Bluetooth Gateway for years. It works flawlessly. Auto detects my phone every time for Spotify streaming and cycles to the cars Bluetooth for phone calls.
It looks like it's out of production, but they can be had on eBay for under $20. https://rover.ebay.com/rover/0/0/0?m...2F282622100569 |
04-17-2018, 09:44 AM | #18 |
Rep 804
Drives: Some fun stuff
I had the Tune2Air WMA3000 and it never worked in my car. The music would constantly pause and the radio display would shift between messages. It was a complete mess that the manufacturer had no way to fix. So just an FYI---this setup doesn't work on all cars, particularly in my case, those equipped with the standard professional radio.
I'm now looking for another good streaming bluetooth option. |
GeorgeA758.00 |
04-17-2018, 10:05 AM | #19 |
Rep 133
I have an 11 (06/10 prod date) without the combox, and the Tune2Air works great. It does have a few hicups here and there but 95% of the time it works as it should. Can use steering and radio controls and song info is displayed in iDrive as well and all I stream is Spotify. Would like to do a combox retrofit one day but some places charge a ton for them. Find a used compatible combox and pay for remote coding from Alex at alpine. Will probably end up being way cheaper than going with some of these other vendors. Some of them are still charging $1000.00 for this retrofit.
04-17-2018, 11:20 AM | #20 |
Rep 1,566
My Tune2Air works well enough that I wouldn't bother doing a combox retrofit. If I did anything, it would be a full NBT EVO retrofit to make it worthwhile.
04-17-2018, 11:28 AM | #21 |
Rep 1,374
honestly retrofitting or updating i-drive is waste of money
it will cost a lot especially when including install. The real Catch is that not only our phones are changing quickly, the i-drive changes quickly. The one you get installed with new maps, new functions, bluetooth etc are already an "old" system you are "updating"... I mean these days a sub 25K car has wireless charging. Just get the Tune2Air, plug it in, music quality is good as oem and you control your music on your steering wheel like the OEM bluetooth unit.
04-17-2018, 11:32 AM | #22 | |
Rep 1,566
I've heard the sound quality over combox is a little bit better than Tune2Air, but not sure how true that is. With that said, I've never had any sound quality complaints with my Tune2Air.
