05-25-2018, 01:40 AM | #1 |
Rep 14
Rough idle on cold start, oily spark plug tip/thread
Been owning this car for 4 months now, one day I noticed the minor shake from the engine while cold start but will go away when the engine warms up.
Figured it could be the carbon built up on the spark plug. So I went ahead replaced all my spark plugs I noticed oily tips/threads on the old plugs for my bank 5 and 7. The replacement solved the problem for 2 weeks but the problem came back again. It gets better when the engine warmed up or simply by pressing on the throttle (oil on the plug tip gets burnt) But I believe it's not because of the valve cover gasket leak neither the spark plug tubes. I just got them all replaced couple of days ago. Is there anything else that could cause this problem? Is there anything in between the crankcase and the camshaft case like a sealing gasket for the spark plugs? Please help!!! |
05-25-2018, 02:29 AM | #2 |
Rep 2,336
The car runs rich for 30-45 seconds on coldstart, apparently it's for emissions and warming up CATS
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD |
05-25-2018, 07:11 AM | #3 |
Rep 14
05-25-2018, 06:47 PM | #5 |
Rep 2,336
Best to have it checked out by a shop that works on BMWs.
Also; Looking at your mileage completely unrelated but have you gotten your belts replaced yet?
05-25-2018, 10:36 PM | #6 |
Rep 14
Not yet...
I might need to leave that to the shop... but I'm afraid of getting ripped off... that's what most of those shop do these days... Last edited by charlielycq@gmail.com; 05-25-2018 at 10:48 PM.. |
05-28-2018, 01:46 PM | #7 | |
Rep 396
Drives: F13 M6
Production date up to start to 05-2008 has different belt routing and different belt. 06-2008- 2013 uses the updated belt. Its easy to change these, i have done it on my own. |
05-28-2018, 02:41 PM | #8 | |
Rep 2,336
Mdriv3r152.00 |
05-28-2018, 03:48 PM | #9 | ||
Rep 396
Drives: F13 M6
05-28-2018, 07:36 PM | #10 |
Rep 14
I just got an engine service light on, I checked on the OBD it was the cylinder 1 misfire. I figured I could have a broken intake valve... what do you guys think?
