06-03-2018, 04:04 AM | #1 |
Rep 426
S65 max oil
I have a oil drain plug leak so I add oil over time to maintain the bar at the middle line. Recently I checked my oil to see if I needed to add more but it says max oil, is this a sensor issue? Or other possible problems
06-03-2018, 05:34 AM | #3 |
Rep 426
06-03-2018, 07:28 AM | #4 |
Rep 977
The oil sensor is notorious for being slow to read actual oil levels. When you see "MAX" check the control messages to make sure that its not overfilled. It can sometimes just mean you have filled to the top of the range and it settles a bit shortly after driving around. Its not an issue to fix unless the control message says engine is overfilled.
If you see a message about it being overfilled, that is when you would have to take action to drain a little, most easily, from the oil filter area.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... Last edited by Mvy; 06-03-2018 at 07:41 AM.. |
06-03-2018, 10:18 AM | #6 |
Rep 24,867
90% chance the screw thread is damaged.
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
Flying Ace4987.00 |
06-03-2018, 10:25 AM | #7 |
Rep 2,362
///M Power-Belgium64251.00 |
06-03-2018, 10:30 AM | #8 |
Rep 24,867
Positive . Can be done ..
06-03-2018, 11:32 PM | #9 |
Save the manuals!
6032
Rep 6,753
Yes it does. I've personally seen "Oil Level Too High" at least on cars with iDrive before.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
06-03-2018, 11:33 PM | #10 |
Rep 1,171
06-03-2018, 11:51 PM | #12 | |
Rep 18
My temporary drain plug leak fix was a butterfly valve, you can find them at any local auto parts store. Fix for the 1000$ new pan was a heli coil. No more leak. Good luck! |
06-04-2018, 07:13 AM | #14 |
Rep 880
Drives: 2011 E90 M3, 2019 F150
06-04-2018, 07:17 AM | #15 | |
Rep 727
2) not sure why you'd respond to a thread only pertaining to an M engine with information about a non-M car. |
06-04-2018, 08:22 AM | #16 |
Rep 977
max.pdf Just so you can see what I am talking about, here's a screen shot of overfill in the control menu. If I saw this after driving very gingerly and then restarting the car, I would be opening the oil filter area to remove some oil. I've seen this message just after filling 8.5 qts knowing it was not overfull and after driving around the block it went away. The sensor is very touchy.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... Last edited by Mvy; 06-04-2018 at 08:41 AM.. |
06-04-2018, 09:09 AM | #17 |
Rep 656
Max fill is fine. Min level is also fine. Every car has a range of about 1L that the engine can safely operate at. Only above and below those is when action needs to be taken. It is a good idea to add 1/2 liter or so when you reach minimum to ensure it doesn't drop below minimum.
So no, max isn't a sensor issue or other issues. It is a proper accurate reading. |
06-04-2018, 10:06 AM | #18 |
Rep 343
06-04-2018, 09:48 PM | #19 |
Rep 3,007
Many owners who have a stripped oil pan drain plug would use a time-sert to successfully repair it.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
06-06-2018, 09:36 AM | #21 |
Rep 977
The exclamation point in the diamond symbol means you have control messages. Check there to see if it shows overfull. Nice mileage btw.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... |
06-06-2018, 10:38 AM | #22 |
Rep 426
