06-25-2018, 06:45 PM | #1 |
Rep 117
HELP Is this a bad wheel bearing ?!
This sound is awful. The video doesn’t do it justice, also I have noticed my DCT tranny to be a bit louder these days when coming to a stop. Any body have any ideas ? It’s like a on and of constant sound at slow speeds. Seems to come from front right side. You can clearly hear it at the end of the video. Almost like a farting sound lol.
06-26-2018, 05:20 PM | #8 |
Rep 836
Drives: Jerez E92 M3 ZCP "12"
You may want to check shield around the rotor .... I had similar sound when driving slowly due to rock debris was caught between rotor and shield, I had to take off wheel and use a crowbar to wedge it open and It fell out. The grinding is very audible at low speed...and it did cause some vibration at high speed.
06-27-2018, 10:31 AM | #9 |
Rep 1,389
Drives: 2012 E92 M3
Bad Wheel bearings usually make a whining noise, not a squishing sound like in your clip. And you would not hear it at very low speeds.
12 M3 Interlagos Blue/Black
18 Jeep Grand Cherokee (Yeah, it's got a HEMI) 21 X3 Silver/Black(Wife's) 06 330i Monaco Blue/Black (retired) 02 X5 3.0 Topaz Blue/Black (retired) |
06-27-2018, 10:47 AM | #10 | |
Rep 880
Drives: 2011 E90 M3, 2019 F150
Pull the wheel off and make sure nothing is wedged in between the rotor and shield or anything in there. If you've got a pressure washer, crank it up and go nuts on the area. Rubber from the track caught up against the brake shield has caused this (1st video) noise before for me. |
