06-30-2018, 07:15 PM | #1 |
Rep 341
Need suggestions: passenger seatbelt gets hung up
I have an E90, which doesn't have the arm belt extender. The top slot on B pillar where the belt comes out has an upper and lower guide and top plastic guide appears to be cracked and snags the belt. To be sure, I pulled apart the whole b pillar column and found the seatbelt retractor works fine as it still pulls the belt back normally.
What I found was the very top upper guide is cracked (it appears to be plastic) and snags the belt, hindering its ability to retract easily. The lower guide (I think it’s metal) is fine. Think of where the belt peaks and loops back down. It’s the upper guide that is cracked and snags the belt. My thought is if there was something slippery I could try to wrap the upper guide to prevent it from snagging the belt. Ideas? PS....you can’t replace that cracked part alone, or else I would.
Current: E90 M3
Previous: 15' M235i, 12' E92 M3, 03' E46 M3, 98' E36 M3 4 dr, 95' E36 M3 2 dr All the above, missed and wish I kept them all. Last edited by m3peat; 07-01-2018 at 10:53 AM.. |
06-30-2018, 11:14 PM | #2 |
Rep 769
Im not sure if i understand the problem properly but it sounds like the belt slips from that little arm that hand you the belt? If thats the case, i just ironed my belt with breach and it worked again. Over time the belt loses its flat shape and no longer able to grip to that arm. Hope that helps
07-01-2018, 10:48 AM | #3 | |
Rep 341
Hope this helps clear it up. |
