06-23-2008, 12:50 PM | #1 |
Rep 81
Gas tips...
Since MPG is a pretty hot topic with our Ms...here are some pointers I came across...
Here at the Kinder Morgan Pipeline where I work in San Jose, CA we deliver about 4 million gallons in a 24-hour period thru the pipeline. One day is diesel the next day is jet fuel, and gasoline, regular and premium grades. We have 34-storage tanks here with a total capacity of 16,800,000 gallons. Only buy or fill up your car or truck in the early morning when the ground temperature is still cold. Remember that all service s tations have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening....your gallon is not exactly a gallon. In the petroleum business, the specific gravity and the temperature of the gasoline, diesel and jet fuel, ethanol and othe r petroleum products plays an important role. A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps. When you're filling up do not squeeze the trigger of the nozzle to a fast mode. If you look you will see that the trigger has three (3) stages: low, middle, and high. In slow mode you should be pumping on low speed, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumping on the fast rate, s ome other liquid that goes to your tank becomes vapor. Those vapors are being sucked up and back into the underground storage tank so you're getting less worth for your money. One of the most important tips is to fill up when your gas tank is HALF FULL or HALF EMPTY. The reason for this is, the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount. Another reminder, if there is a gasoline truck pumping into the storage tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some of the dirt that normally settles on the bottom. Hope this will help you get the most value for your money. DO SHARE THESE TIPS WITH OTHERS! WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW. I thought it might be interesting for you to know which oil companies are the best to buy gas from and which major companies import Middle Eastern oil. These companies import Middle Eastern oil: Shell........................... 205,742,000 barrels Chevron/Texaco.................. 144,332,000 barrels Exxon /Mobil.................... 130,082,000 barrels Marathon/Speedway............... 117,740,000 barrels Amoco................... ..........62,231,000 barrels Citgo gas is from South America, from a Dictator who hates Americans. If you do the math at $30/barrel, these imports amount to over $18 BILLION! (oil is now $90 - $100 a barrel ) Here are some large companies, with several US gas stations each, that do not import Middle Eastern oil: Sunoco..................0 barrels Conoco..................0 barrels Sinclair................0 barrels B P/Phillips......... ...0 barrels Hess....................0 barrels ARC0....................0 barrels If you go to www.Sunoco.com, you will get a list of the station locations near you. All of this information is available from the Department of Energy and each is required to state where they get their oil and how much they are importing. |
06-23-2008, 01:12 PM | #2 |
Rep 127
Drives: 08 M3 Spark. Graph. 6MT Coupe
Wow. Very interesting. Thanks for the post.
06-23-2008, 01:12 PM | #3 | |
Rep 1,973
MDCT ... so you can drive and eat a hamburger at the same time. |
06-23-2008, 01:42 PM | #4 |
Moderator
7525
Rep 19,368
06-23-2008, 01:51 PM | #5 |
Rep 1,238
Drives: 2020 X6M Competition DG
Great tips! Thanks
06-23-2008, 02:24 PM | #6 | |
Rep 93
another thing. gas station tanks are held underground. the ground is an excellent insulator... and for that very reason people use underground piping with water pumps to keep houses temperatures regulated at a constant year round temperature. the gas in the tanks isn't going to fluctuate temp enough from day or night to make any difference at all. maybe if you pump it extremely slow where once it gets in the hose it is warming up, but even then i believe the pump measures the fuel before the hose, not at the nozzle. if you want to make an effort to get better gas mileage, use the tried and true methods. 1. keep the car light. remove any excess crap you may have in the car that you don't need. 2. keep tires inflated properly 3. drive as smooth as possible. anytime you blip the throttle the ECU will go into accel enrichment and add fuel in anticipation of a hard acceleration. also, prolonged hard acceleration the car will transition to open loop fuel tables where the car runs more rich then at a steady pace where the car uses the o2 sensors for feedback in a closed look system (i.e. best fuel mileage). by being gentle with the throttle, smooth, slow accelerating you'll see far bigger gains in mpg then any of the above "tips" including my own. sure having 400 hp is fun, and obviously there is a time and a place to use all 400 of them, but on your way to work in traffic, or just driving around town, it is totally unnecessary to accelerate hard from a light, or to catch the car in front of you only to slow down and match speed. |
06-23-2008, 02:26 PM | #7 | |
Rep 6,007
06-23-2008, 02:30 PM | #8 |
Rep 6,007
Got nothing to do with necessity.... It's fun, that's why I bought a 414hp car.
06-23-2008, 02:43 PM | #9 | |
Rep 93
i know what you mean, i have a 600bhp (500awhp) car but i still get 23-24mpg. i know the time and the place to use the power, like putting to shame the cls55 amg v8 kompressor this morning. i guess i'm just used to the power now, first 2 years i got 15-18mpg. then i didn't need to hit the throttle all the time because i still got to where i was going in the same amount of time (traffic and lights ). |
06-23-2008, 02:48 PM | #10 |
Rep 6,007
I'm not trying to get anywhere faster, I'm just having fun on the ride there.... Who knows, maybe one day I'll grow up, but I don't see that happening anytime soon
06-23-2008, 04:08 PM | #12 |
Rep 832
Check out the hoax website that someone posted...all false info here.
2019 M5 Competition / Acquired: 04.12.2021
2020 VW Atlas / Acquired 03.15.2020 2023 X7 M-Sport / Acquired: 11.19.2022 Retired: 2011 E90 ZCP M3, 2014 Range Rover Sport, 2006 Audi S4 V8, 2011 E92 ZCP M3, 2011 BMW X3, 2009 Infiniti G37S Coupe, 2006 Audi A4 S-Line 2.0T, 2008 E92 335i, 2005.5 Audi S4 V8, 1990 E30 325is |
06-23-2008, 04:13 PM | #13 |
Rep 1,020
Past: 2008 M3 (E93) naturally aspirated V8 realness! Past: 2012 740Li (F02) M-Sport (European Delivery) Present: 2016 750i (G12) M-Sport |
06-23-2008, 05:10 PM | #14 |
Rep 844
Err, wtf is the difference between 'half full' and 'half empty'?
E92 M3, Breyton GTS 19s, black and carbon all over Factory Mini John Cooper Works 211bhp MK Indy R track car (road legal) 300bhp+ per ton, sequential box VW Tiguan 4x4 |
06-23-2008, 05:13 PM | #15 |
Rep 6,007
one's a pessimist the other's an optimist... not sure which one is which though
