08-01-2018, 11:02 AM | #1 |
Rep 977
Does the S65 have a engine case breather?
Hey Folks,
With both my valve cover gaskets going on me and an annoying oil cap and valve cover leak ever since I SCed the motor, I am getting ready to do some service on the car and was thinking about checking the case breather to see if its contributing to the leak (not allowing the additional pressure to vent fast fast enough). I did a search but didnt find much. One thread said the S65 has no breather per se, but I read other posts where it was suggested there is one. Has anyone touched this before and know what goes into checking it for clogs? Where is it located? Can I get to it without pulling the huffer off? I suspect I am getting a bit over normal case pressure now with the SC and that is encouraging my leaks. Im sure its also cause the seals are older and need to be replaced. Appreciate any knowledge you can lend on this topic.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... Last edited by Mvy; 08-03-2018 at 02:08 PM.. |
08-03-2018, 01:59 PM | #3 |
Rep 977
Thanks m3 post. I tried the old and new oil cap . Right now im on the new oil cap with black high temp rubber weld holding it to the plastic. As long as I get it really super free of oil on the rubber and mating surface, I have minimal leakage at the cap now. But that corresponds with a more noticeable leak at the valve covers giving the vapor a place to go other than through the cap. Thats why I was thinking it would be good to check all of these items at once. Ill give the new cap a go.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... |
08-03-2018, 05:47 PM | #4 |
Rep 977
Much appreciated. I ordered the cap. I'm doing gaskets next month. Will keep you posted but it looks far more robust than the current one. And it has m badging which is nice!
08-06-2018, 01:43 PM | #7 |
Rep 977
Caps already here. That was fast!
08-06-2018, 05:27 PM | #8 | |
Rep 466
Mvy541.50 |
08-07-2018, 05:20 AM | #9 |
Rep 977
Thanks all. Im ordering the PCV replacement with seals and hose. Will install next month. See my poll on valve cover gaskets as I am trying to make a decision on that ;-)
Here are the parts to order for anyone searching this thread in the future: PCV Valve:11617836553 PCV vent valve seal:11157838370 and 11157838369 PCV hose:11617838288 Total cost from FCP Euro $76.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... Last edited by Mvy; 08-07-2018 at 05:58 AM.. |
XKxRome0ox1589.00 |
08-07-2018, 07:45 AM | #11 |
Rep 62
I can had some info on your question about the pcv system.
The s65 internal "pressure" is breathing freely through the two oil separtors on the valve covers. Oil vapors go through the intake and back through the 8 throttles. If oil droplets accumulate: they drop back into the check valve behind the bloc. I am quoting directly from the Self Study Program of the S65/e90: "The oil separators are bolted onto the cylinder head covers. The connection between the oil separator and the intake manifold is not screwed but plugged. This reduces the risk of incorrect assembly. As is typical for the M series, no crankcase pressure control is mounted/integrated" |
08-07-2018, 07:57 AM | #12 |
F15 daddymobile
2356
Rep 3,521
Changed the valve covers and gasket?
08-07-2018, 08:15 AM | #13 |
Rep 977
Then help me understand what the Non Return Valve (PCV) part x11617836553 does please. I was told it is the pressure release valve for the crank case. Do I need to replace the oil separator too part 11157848155?
08-07-2018, 08:43 AM | #14 |
Rep 62
The valve you are talking about is a check valve, located in the back of the engine.
It allows oil droplets that are located in the intake plenum to be drained back into the engine. Your engine is breathing through the two oil separators and I dont see how your separators could be block. If you had overpressure inside the block your crank seals would also be pissing oil. |
Mvy541.50 |
