08-17-2018, 06:47 AM | #1 |
Rep 163
Post rod bearings been done, weird sound
Hey guys have had my rod bearings done about 500km ago and has been fine so far,
But today I could hear a noise on idle, can't work out what it is exactly. I have posted a video of it below, any feedback would be great. Thanks |
08-17-2018, 07:27 AM | #2 |
Rep 980
Interesting, call me crazy, but I thought I heard a similar sound on my car.... now I want to know. My car runs perfect, no issues, bearings were done preventively at 79k (and were not bad at all). I also just had my primary cats welded back on.....(nyc) inspection :
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
///M Power-Belgium64254.00 |
08-17-2018, 07:32 AM | #3 | |
Rep 163
I was thinking possibly clutch or flywheel but the noise doesn't go away when I push clutch in. Also probably should mention the car was sitting for about 2 weeks before I took it for a drive and heard this noise |
M3LISSA809.50 |
08-17-2018, 07:39 AM | #4 |
BimmerPost Supporting Vendor
3771
Rep 2,912
Drives: 2011 E93 M3
I don't hear anything alarming.
08-17-2018, 07:47 AM | #5 |
Rep 233
You left it for 2 weeks and forgot what the m3 sounds like lol, drive it more!
Audioslave686165.00 |
08-17-2018, 07:49 AM | #6 | |
Rep 163
08-17-2018, 08:03 AM | #7 |
Rep 1,389
Drives: 2012 E92 M3
I definitely hear some sort of knocking. My car doesn's sound like that from inside.
Can't hear it when you rev it up but the exhaust is loud so that might be why. Shoot the video around the engine compartment and maybe it will pickup the sound better and less of the exhaust noise..
12 M3 Interlagos Blue/Black
18 Jeep Grand Cherokee (Yeah, it's got a HEMI) 21 X3 Silver/Black(Wife's) 06 330i Monaco Blue/Black (retired) 02 X5 3.0 Topaz Blue/Black (retired) |
08-17-2018, 08:20 AM | #8 | |
Rep 163
08-17-2018, 08:25 AM | #9 |
Rep 233
The shop who installed it should provide a warranty if it's bearing related, check with them perhaps?
08-17-2018, 08:43 AM | #10 |
Rep 7,130
Can't hear any knocking at all but if you refer to what in my ears sounds more like a ticking noise, I have the same at certain rpms before as well as after RB replacement. Use to go away after a few good red lines though (strange but true, guess I granny the car too much..). Will be interesting to hear your other video.
Cheers |
08-17-2018, 09:01 AM | #11 | |
Rep 163
08-17-2018, 09:04 AM | #12 |
Rep 1,389
Drives: 2012 E92 M3
I hear the ticking too but if you turn up the sound and listen through the ticking you can also hear a slight knocking also. You can only hear it in the beginning and as he starts to rev. Once the revs go up all you hear is the exhaust.
Might be normal but I don't hear that on mine.
08-17-2018, 09:05 AM | #13 | |
Rep 163
08-17-2018, 09:51 AM | #14 | |
I got lei'd
846
Rep 7,594
08-17-2018, 10:46 AM | #15 |
3771
Rep 2,912
Drives: 2011 E93 M3
I don't hear any knocking. Light ticking and exhaust sounds due to the tubular headers often fool people into thinking they're in imminent danger.
Turn off the Air Conditioning and see if you can still hear what you're worried about. Compressors can cause a sound just like rod bearing knock. |
08-17-2018, 10:52 AM | #16 | |
Rep 163
I was thinking as it s a 6mt that is could be something to do with clutch or flywheel but it continues happening even when clutch with depressed: |
08-17-2018, 01:25 PM | #18 |
Rep 4,252
Drives: 2017 M3 MG/SO ZCP DCT
Could it be ur fuel injectors firing off??
08-19-2018, 07:15 PM | #20 |
Rep 5,034
Youre freakin paranoid dude. That engine sounds beautiful. If you had rod bearings done just recently and you are already freaking out you should just sell the car before it starts costing you sleep, or your hair begins to fall out. Or you can go to a different shop and have them do the rod bearings again every 5000km.
08-19-2018, 07:51 PM | #21 | |
Rep 388
bosse92m339.50 |
08-19-2018, 08:10 PM | #22 |
Rep 742
Take a video with your hood popped in the engine bay. I have a very similar sound but mine was way louder. I thought it was rod knock, took it to MRF, turns out metal shavings in my oil and filter. He pulled the bottom end and bearings didn't spin but were very damaged, crank was fine. Bearings were replaced and he explained I still have the ticking noise, I'm 90% sure that's what I heard the morning I thought I heard rod knock so I don't think I ever had rod knock it's just coincidental that my bearings were failing lol. Malek explained that he believes it's Vanos related, possibly the solenoids or the actual Vanos gear. I'd like to see a video of your engine with the hood popped as your hear it much easier that way atleast on my car. But from what I hear on the video your sound sounds exactly like mine. I will say I've driver 3k miles since the bearing job and no issues so it's not rod bearing knock or tick.
bosse92m339.50 |
