08-19-2018, 03:42 PM | #1 |
Rep 8
Drives: 17' BMW M3
DCT jerkiness in 3rd gear
I've been experiencing an issue with jerkiness.
Usually in third, at constant throttle or slightly off throttle it will start to pulse a bit. Around 1200 rpm, driving through parking lots/slow traffic. In efficient and D1. I've driven manual cars, and I understand what the transmission is. But this particular quirk doesn't seem right. An unrelated thing, but that has bugged me since I got the car, there's a electrical whine at a certain point on the throttle. A little off of the point needed to maintain speed at 70. Anybody else have that? |
08-19-2018, 04:42 PM | #2 |
Rep 3,825
By it's nature, you will get some jerkiness at slow speeds with a DCT. I wouldn't consider any electrical whine acceptable, not sure I've ever heard of that issue. I would take it to the dealer ASAP.
08-19-2018, 05:01 PM | #3 |
Rep 663
I found D3 to be intolerable and unusable when it came to jerkiness in low gear. I never use it anymore.
I keep at D2 all the time. I think it's perfect, I have it set that way for both M buttons too.
2019 540i | Black Sapphire | Black Dakota Leather with Blue Stitching | M Sport Package | Executive Tier | Driver Assistance | Parking Assistance | HK | M Sport Brakes | Leather Dashboard
2016 M3 | YMB | Black Extended Merino | CF Roof | CF Trim | DCT | Adaptive | Executive |
SMGCFP593.50 |
08-19-2018, 08:52 PM | #4 |
Rep 2,924
Jerking in slower speed, under 15mph, is normal.
But you should check it out with Dealer for peace of mind..
Currently: '22 Ferrari F8 | '24 Mercedes G63 | '24 Porsche GT3RS | '24 Volkswagen GTI
Previous BMWs: 340i, 740i, 745Li, M3, M4 Previous Others: Audi, Ducati, Honda, Infiniti, Land Rover, Mercedes-Benz, MINI, Mitsubishi, Porsche, Toyota, Volkswagen |
08-19-2018, 09:07 PM | #5 |
BMWphile
93
Rep 132
Is it normal for the DCT to make a clunk noise at highway speeds? For instance, cruising at 75 mph in 7th. Take your foot off the gas, put it back on, audible clunk which you cannot feel. Doesn't always do this.
08-19-2018, 09:20 PM | #6 |
Rep 612
That doesn't sound normal. Are you sure that's not the burbles from the exhaust?
2018 F80 M3 Comp, Silverstone Metallic II, w/ black 666M (Ordered: 7/9/2017 | Pickup 9/9/2017)
1998 E36 M3, Cosmos Schwarz Metallic 2009 E82 135i, Montego Blue |
08-19-2018, 09:30 PM | #7 |
BMWphile
93
Rep 132
Definitely not burbles. It's not really a clunk, more of a metallic click. Almost like the clutches are re-engaging. Does it almost always letting off and putting your foot back on the gas at highway speeds. I also have GTS DCT software, it did it before this as well. So I'm thinking its just how the DCT is.
08-19-2018, 09:50 PM | #8 | |
Rep 806
Drives: 2016 lci m3 mw
f80 m3 lci mw
08-19-2018, 10:06 PM | #9 |
BMWphile
93
Rep 132
Can confirm the GTS software is a MASSIVE Improvement. No more jerkiness in the throttle period. The only weirdness is what I mentioned above, and what the car has done for a long time; metallic clicks from the DCT when you re-engage the throttle at highway speeds in higher gears.
08-19-2018, 10:34 PM | #10 | |
Rep 2,863
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
08-20-2018, 08:27 AM | #11 | |
Rep 3,396
08-20-2018, 08:30 AM | #12 | ||
Rep 2,863
shortseller1002.50 |
08-20-2018, 08:54 AM | #13 | |
Rep 20,742
Drives: 2021 911 turbo
Off throttle the diff unlocks for stability and locks back up for traction when you get back on the throttle. The clutches in the diff make a perceptible clicking sound when in action.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
08-20-2018, 11:55 AM | #14 |
BMWphile
93
Rep 132
It does sound like its coming more from the rear of the car than the DCT at times. So is this a normal noise then? It is like something clicking back into place for sure, and doesn't always do this. Do you experience this in your car when you get back on the throttle at highway speeds?
08-20-2018, 04:29 PM | #15 | |
Rep 20
Shop foreman listened to it before 1200 miles... said come back and see me later, but shook it off for the most part. Call BMW USA and let them know. They will write it down. At least it will be two of us |
Thescout134947.00 |
08-20-2018, 04:31 PM | #16 |
Rep 20
08-21-2018, 05:40 PM | #18 |
Rep 63
08-22-2018, 10:04 PM | #19 |
Rep 8
Drives: 17' BMW M3
Thanks for the responses everyone.
I will have to make an appointment with the dealer to see about the whine and what if anything they can do about the transmission. |
08-22-2018, 10:28 PM | #20 | ||
Rep 115
08-23-2018, 08:26 AM | #21 |
Rep 1,975
I've heard the electrical whine a few times on highway at speeds above 100km/h
Sounds like the audio interference you get when you run power cables too close to speaker wire in an aftermarket stereo install I can't replicate it, and it's totally random |
