09-04-2018, 11:41 PM | #1 |
Rep 533
What conditions trigger radiator fan?
I live in AZ, so it's 100+ five months of the year. My car's temp is always where it's supposed to be, regardless of ambient. I run A/C all the time.
I might be nuts, but I think my fan is running more this year than last. And at at a pretty high speed, based on the noise. So I'm wondering, what conditions cause the fan to run? Is there something that might not be working correctly that would cause the fan to run all the time? I've had the car for 16 months and it seems to run more than a year ago. Would like to know how other hot weather cars in AZ, CA, and NV behave when it comes to their fans. Thanks.
1972 Bavaria> 1973 3.0Si> 2013 328i> 2009 E92 M3> 2013 F10 M5: Singapore Gray over Sakhir Orange, Executive, Driving Assistance, B&O
09-05-2018, 08:23 AM | #2 |
Rep 386
If I remember correctly it's a multitude of factors....
Ambient temp vehicle speed a/c pressure coolant temp and I might be missing one or two others |
09-05-2018, 08:23 AM | #3 |
BimmerPost Supporting Vendor
3769
Rep 2,912
Drives: 2011 E93 M3
It's a Pulse Width Modulation fan (PWM/variable speed). The DME controls the speed depending on needs, so the speed will vary. You may only hear it when it goes full speed, so you're probably not able to accurately compare its current duty cycle to previous years.
A/C use will turn on the fan as well but will still run at varying speeds as engine temps and refrigerant pressures demand. |
09-05-2018, 12:40 PM | #4 | |
Rep 533
09-05-2018, 12:41 PM | #5 |
Rep 533
Thank you!
