09-26-2018, 02:12 PM | #1 |
DAK 2014 X5
Rep 11
Front Camera Failure, F15
The front camera on my F15 has stopped working which of course is also causing my Surround View to not work and throw an error message on my dash which says "Camera System Failure". I know it's the front because when I activate surround view, it quickly gives me the overhead shot but is all blue in front of my car. The front cam shows a blue screen when activated too. I took the camera out and was hoping the smoking gun would be corrosion on the connector that I could clean off, but this is not the case. Everything looks clean connector-wise. Plugged back in and still nothing. My questions follow:
1) Do you believe the camera itself is suddenly bad? Or should I be looking further into the connection or something similar? 2) If I were to buy a new camera online, does this dealer have to program it to my car, or will it plug and play? 3)Lastly, any great ideas on where to order the camera should I need to do so? or are there aftermarket cameras that I could plug in seemlesly? Lots of questions, I know. I appreciate anyone's insight! |
09-26-2018, 11:24 PM | #3 |
Rep 18,757
Should be as simple as plug n play since you are not replacing the module itself.
Unless there is a newer version of camera where it need to be re-registered.
09-27-2018, 02:58 AM | #4 |
Rep 317
You can buy those cameras used on Ebay, and it should be plug and play as long if its these 4 part numbers
66539352788 66539360369 66539388797 66539213990 X5 F15 Surround View |
M302_imola843.50 DuSh2113.50 |
10-02-2018, 07:21 AM | #5 |
DAK 2014 X5
Rep 11
Turboawd: I'm unsure what the screen does when it get's unplugged. Right now, when I activate the front camera, the screen simply turns blue. I can look into this tomorrow when I take the camera out to check the part number.
10-02-2018, 07:22 AM | #6 |
DAK 2014 X5
Rep 11
r33_RGSport: Thanks for the heads up. This gives me some peace of mind. Here's hoping I can find a comparable camera model. I will advise once I order and install.
10-11-2018, 08:08 PM | #7 |
Mmmmm…
1152
Rep 2,426
Drives: F15
Thanks for this thread, my front camera was damaged about two years ago by a rock (it's a got a crack in the glass); I found a replacement on Ebay, hopefully it's plug and play since I wasn't going to pay the $500 for the new one.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
Russmov1328.00 |
10-11-2018, 10:49 PM | #8 | |
Mmmmm…
1152
Rep 2,426
Drives: F15
I pulled one out of my mirror (since I cracked my mirror housing), this camera doesn't feel like a $20 item. It's metal, well build, solid construction. You know that GoPro they sell for $400? This feel better quality. That said I think the $500 is a bit ridiculous because image resolution is atrocious compared to a GoPro, but I couldn't find it for $20.
BMW CCA 509766 |
10-11-2018, 11:48 PM | #9 | ||
Rep 1,343
Drives: 2015 BMW X5 xDrive 35i
2015 BMW X5 xDrive 35i-Current
2016 BMW X4 xDrive 28i-Sold 2014 Lincoln MKX-Sold |
10-15-2018, 04:46 PM | #10 |
Mmmmm…
1152
Rep 2,426
Drives: F15
Anyone know if I need to remove the front bumper entirely or is there an easier way? If I pop off the top 5 bumper retainer screws, I can see the camera and the mounting bracket, but my hands do not fit in there. I cannot get access to it from removing the front grills either.
Yeah, I was thinking like where is this guy getting this for $20?!
BMW CCA 509766 |
10-30-2018, 10:55 AM | #11 |
DAK 2014 X5
Rep 11
I was able to get to my camera very easily from the top of the engine compartment. I removed a plastic cover near the front and was able to reach down and unhook it. Should be VERY simple!
11-04-2018, 05:32 AM | #12 |
DAK 2014 X5
Rep 11
I purchased my new(used) camera this week from EBAY, and it was out of a 2018 X5. Part number is 66539213990. I plugged it in yesterday to hopefully get my surround view back, but the camera doesn't work! Now what? Is it the connector?...and if so, how do i fix this? Could the camera be bad from Pacific Motors on Ebay?
11-04-2018, 10:36 AM | #14 | |
Mmmmm…
1152
Rep 2,426
Drives: F15
Finally I gave it up and bought the camera from the dealer, and it worked immediately. Plug and play. Same part number you listed. I don't know, maybe your Ebay camera is bad? Needs to be coded? If you'd like, try I can mail you my old camera with the cracked lens, if you can get an image (albeit a blurry one), but at least you'll know if it's the camera module or the camera itself...
BMW CCA 509766 |
11-05-2018, 03:03 PM | #15 | |
Rep 159
i was thiniking f15 from 14 to 18 the same part |
03-19-2019, 01:44 PM | #16 |
Rep 1
Help. Front camera replacment
Hi
I need to replace my cracked front camera, I’ve got the new one off eBay Tried to remove the old one and found it impossible to reach into the housing between the grills just below the bonnet. It so narrow I can’t reach and undo the fixings or connector Anyone with some advice please?... |
03-20-2019, 09:14 AM | #17 | |
Mmmmm…
1152
Rep 2,426
Drives: F15
BMW CCA 509766 |
04-17-2019, 01:17 PM | #18 |
Rep 4
I have a crack in front camera of my 2016 BMW X5 50. But i can see a clear picture on my screen inside the cabin. Just the hairline of the cracks show up on the screen. Do you think its just the housing that i need to replace ? I do not have the part number of the glass encasing. Can anyone share the part number of just the outside glass encasing ?
04-17-2019, 08:35 PM | #19 | |
Mmmmm…
1152
Rep 2,426
Drives: F15
If it's clear for now, perhaps it's not worth replacing. Mine got cloudy after two years then I finally replaced it.
BMW CCA 509766 |
04-19-2019, 10:13 AM | #20 |
Rep 4
Thanks for your reply. Really appreciate it. You mentioned that you replaced it after 2 years. Was it plug and play or did you have to re-calibrate the camera ? TIA.
04-19-2019, 10:14 AM | #21 |
Rep 4
Btw dealer told me 6 hours of labor for replacement and $450 for the part itself !! I would rather have me labor the replacement and save some green. Thanks in advance
04-19-2019, 11:14 AM | #22 |
Mmmmm…
1152
Rep 2,426
Drives: F15
I replaced it myself. It was pretty easy. Dealer probably wants to (or say they will) disassemble the entire front end which isn’t necessarily. You can access it from the top in front of the engine. Part is quite expensive. eBay I got three different parts all didn’t work. The dealer part was plug and play for me. $450 sounds about right (unfortunately).
BMW CCA 509766 |
Tags |
camera, camera system failure, front camera, surround view |
