09-27-2018, 11:15 AM | #1 |
Rep 29
What oil for Diesel?
Hi,
Other than the dealership oil, what oil is best for the X5 diesel? I ordered Mobil 1 ESP because I saw someone mention it on here, but the Mobil 1 website says that have no oil that works for the X5d so that left me confused. Castrol says their Edge C3 is good to use. Can I use the Mobil 1 ESP or go with the Castrol? Thank you! |
09-27-2018, 12:57 PM | #2 |
Rep 317
As long it meet BMW LL-04 (5w-30) or LL-12fe (0w-30).
I personally use Mobil 1 ESP 5w-30 it’s very robust and heavy for 5w-30 oil. On another note However there is a new Mobil esp 0w-40 oil that was introduced for the now corvette that has BMW LL-04 rating that seems to be a very good all season weight oil, but it’s very difficult to find in US at the moment. Last edited by Mr.47; 09-27-2018 at 02:28 PM.. |
09-27-2018, 06:46 PM | #3 |
Mmmmm…
1152
Rep 2,426
Drives: F15
The BMW oil is basically rebranded [Shell] Pennzoil Platinum Euro L 5W30 which currently sells for $6.50/Qt plus tax on Amazon, right now there is a $2/Qt rebate, so only $4.50/Qt pretty solid price. (BTW it's cheaper to buy them per bottle than per case, go figure)
That said I get a case from the dealer for the BMW 5W40 (I have the gas motor), $90 for 12 L, pretty good price since my fill is 9.5 Qt equaling 9 L. No half bottles after an oil change. Only $5 more than Amazon regularly priced, not too bad, dealership parts sees me regularly for items, they are happy, I get good prices on stuff, I'm happy. That said I avoid the Mercedes parts department. $90 for wipers vs $25 for the same Bosch part?
2015 BMW X5 xDrive50i
BMW CCA 509766 |
09-27-2018, 09:07 PM | #4 |
Rep 182
Funny thing, the Mobil 1 website used to have ESP 5w30 as for bmw diesel. Now, I don’t see it as listed for bmw anymore. Also, our 14 x5d started life using bmws 5w30 oil. In the last 2 or 3 years, bmw switched to 0w30. I wonder if mobil 1 esp lost the ll04 rating because of the weight. Even still, I use the esp 5w30 for my x5d as it is a low saps oil. I sent in an oil sample to blackstone, so I’ll post it up when it arrives
09-27-2018, 09:19 PM | #5 | |
Rep 1,066
Drives: 2015 X5 50i M Sport
2019 Cayenne Turbo
Gone but not forgotten: 2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport |
09-27-2018, 10:14 PM | #6 | |
Rep 317
Update: Did a little research apparently you can use Mobil 1 but it must say on the bottle Mobil 1 formula ESP 5w-30 (been phased out) if it just says Mobil 1 ESP 5w30 (new version) then it’s not USABLE. Differents is the Sulfated ash was increased from 0.6 to 0.8 (higher is not good for emission systems) and it’s marginally thinner. Citation Mobil 1 ESP formula 5w30 Mobil 1 ESP 5w30 Last edited by Mr.47; 09-28-2018 at 12:30 AM.. |
09-28-2018, 12:28 AM | #7 |
Well versed in the care and feeding of BMWs
261
Rep 733
I used Mobil 1 in all my gas engines until it was revealed that to conform to WALMARTS pricing needs MOBIL 1 was reformulated, several years back. The product no longer met minimum standards for my needs. LIQUI MOLY is the replacement.
For my 35d the additional oil change regimen I have followed currently uses LIQUI MOLY or ROTELLA at 7k change intervals. Subsequent lab analysis bears out both as being well suited to my needs. Both have LL04 specification. I encourage you to drill down through the posts about this elsewhere on this forum. This is a popular topic.
B&O, parking assistant, executive package, 3rd row seats and the manual rear shades are the ONLY items we didn't order. Having everything else makes our F15d a NICE ride.
09-28-2018, 09:08 AM | #9 |
Mmmmm…
1152
Rep 2,426
Drives: F15
Just get the Pennzoil which is basically same as BMW stuff.
It seems all the Mobil 1 stuff lost BMW approval. I used to used Mobil 1 0W40 on all my cars. Not anymore. |
09-28-2018, 09:24 AM | #10 |
Rep 1,081
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
In both my X5s I just use the dealer oil as after CCA disc its about same price as the 2 mentioned alternatives.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
F87 S55158.00 |
09-28-2018, 05:17 PM | #12 | |
Rep 182
Edited. I checked the bottles and it’s the ll04 formula that I used Last edited by BillK; 09-28-2018 at 06:22 PM.. Reason: Correction |
09-29-2018, 01:46 PM | #13 |
Rep 44
I've been using Pennzoil Platinum Euro L 5W-30 which is LL-04 approved for my diesels for 3 years now. At $23 per 5qt jug at walmart (cheaper when you do the rebates) it's a no brainer. I couldn't find a better and more readily available oil than this.
2011 335D sport
2014 X5 35D m-sport 2014 X5 35I luxline |
09-30-2018, 10:08 PM | #14 |
Rep 60
Mobil is not a "true" synthetic. Have to go to Redline, Amsoil, Motul, and the like for group IV or better, true synthetics (I’ve always used Motul and they have a bmw rated version for diesels).
10-01-2018, 12:18 PM | #15 |
Rep 401
I have been using Shell Rotella diesel specific 5w-40 in my E70 the last few changes with good results. I also recommend everyone change their diesel oil frequently due to the amount of soot these systems collect. Keeping clean oil in there will help the motor run cleaner over the long haul.
2015 BMW X5 35d Msport Carbon Black/Mocha Nappa 2013 Cadillac Escalade Platinum Diamond White Pearl/Cocoa 2007 BMW M6 Sapphire Black Metallic/Black 2005 Ninja 636 Lime Green |
10-01-2018, 07:56 PM | #17 | |
Rep 182
Please tell us how Mobil 1 doesn’t meet your needs |
10-03-2018, 01:56 AM | #18 | |
261
Rep 733
Mobil 1 is a different product now compared to just a few years ago. For you commuters M1 is probably just fine. I find that towing my toys through all sorts of weather extremes up and down the west coast requires a better product. Pull a sample of your oil and let me know what Blackstone, or whoever you choose, says about your choice. I’ll still be enjoying my F15 long after you turn your lease back in.
10-03-2018, 11:02 AM | #19 | |
Rep 317
However I can see you point for Mobil 1 developing/consolidating oils for the mass consumers (ie Mobil 1 Annual Protection Oil for Supermarket) however Mobil 1 ESP a speciality oil and is unlikely Mobil 1 will reformulate those oils for sake of keeping on supermarket shelves only reason Mobil 1 got drop is because of Shell recently won suppliers for BMW oils and mobil 1 just reformulated their ESP oil, it be a few years before BMW starts approving other oils brands. |
10-05-2018, 08:35 PM | #20 | |
Rep 182
https://f15.bimmerpost.com/forums/sh....php?t=1540029 I don’t lease cars, I buy them to keep for long term. If you noticed my sig, my 95 M3 is approaching 24 years old. And yes, I’ve put mobil 1 in it since ‘97 The ‘11 M3 is takes castrol because mobil doesn’t make a compatible oil |
10-06-2018, 09:03 PM | #21 |
Rep 570
I use 5W-40 Shell Rotella T6
Shell Rotella T6 Full Synthetic Heavy Duty Engine Oil 5W-40, 1 Gallon https://www.amazon.com/dp/B01LH7L0KS..._mIwUBbX6QMNV9 |
10-07-2018, 02:59 AM | #22 | |
261
Rep 733
