09-29-2018, 08:05 AM | #1 |
Rep 366
Wanting to improve the sound system, ideas?
We currently have the H&K in our 2014...
We upgraded from a 2006 E90, with the high end sound system, and it sounded better than the X5 on every account. Don't get me wrong, the X5 doesn't sound bad, but its lacking. Ive adjusted the EQ properly, and am using a high end sound source, not XM/Sirius.... So, what options are out there for an upgraded sound system in these? I don't want to get into major installs, with external amps, and subwoofers. Im not into that with this vehicle. Ive seen places like Bimmer-tech and Bavauto sell complete systems, but I don't know if they are worth the money etc. Thanks
2014 X5 35d X-drive. Space Gray Metallic. Mocha Dakota Leather.
09-29-2018, 08:45 AM | #2 | |
Rep 277
09-29-2018, 01:49 PM | #3 |
Rep 366
Thats why I asked, I know a few of the members here have done upgrades. Curious as to what works, and what doesn't.
09-29-2018, 02:54 PM | #4 |
Rep 18,757
I have sold and installed BavSound to a full range of BMW and Mini cars.
So far I haven't heard any complaints from any of them. BavSound have satisfaction guarantee. So, nothing to lose if you are planning to do installation yourself.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
weareweird6988.00 |
09-29-2018, 04:02 PM | #5 |
Rep 277
The biggest thing I have seen across with bmws is upgrading the one amp with a bimmertech amp and dsp. If you are talking about installation. The doors are pretty easy, the under the seat woofers aren't too bad either.
weareweird6988.00 |
09-30-2018, 03:59 PM | #7 |
Rep 146
Have a nice new Bavsound set for sale: https://f15.bimmerpost.com/forums/sh....php?t=1474195
weareweird6988.00 |
09-30-2018, 04:37 PM | #8 |
Rep 127
I did the bavsound in my e53
I had the base system and I did the speakers. That helped a lot.
In my f15 I have the H&K and it sounds more or less the same with the surround disabled and the eq set right. Before I did anything serious Id dynamat the panels. That helped a ton. Then Id add an amp. But I personally only think the lows are the issue. So Id want a woofer, maybe the under seats or the jbl stealth. Start with the dynamat. Will never hurt and its cheap. |
weareweird6988.00 |
09-30-2018, 08:49 PM | #10 |
Rep 535
You guys should sit in a car with B&O. 100 times better than HK. I miss it.
Any idea how Bavsound compares to it? |
weareweird6988.00 |
10-01-2018, 07:54 PM | #12 |
Rep 366
Having messed with sound deadener, I don't feel like messing with it in this thing. Too much crap to go around lol The deadener is more for isolating the speaker, and keeping the exterior noise OUT, which gives better clarity.
Id like to try the B&O out, but I don't know ANYONE else with an X5. Ive never heard of MPE. I really want to avoid adding an external sub and amp. I already have something I can use to do that if I really wanted to. Its literally sitting in the basement, out of our original 325xi we used to have years ago.
10-01-2018, 07:57 PM | #13 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
Freude am Fahren.
weareweird6988.00 |
10-01-2018, 08:02 PM | #14 | |
Rep 984
weareweird6988.00 |
10-01-2018, 08:10 PM | #15 |
Rep 703
I have HK on X5 and B&O on X6M. In my opinion is not a huge difference and for sure is not worth the price if you buy the car new. But the center speaker is awesome!
weareweird6988.00 |
10-01-2018, 08:13 PM | #16 |
The limit of adhesion is my home.
1702
Rep 3,778
BAVSOUND is amazing......2 of my friends have it and it really changed the sound. one of them even has the regular Hi-Fi system. totally worth it in my opinion. getting an X5 soon with hi-Fi and installing it for sure
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
weareweird6988.00 |
10-01-2018, 08:15 PM | #17 | |
Rep 366
I had a feeling
As far as replacement speakers. What has everyone used, and what does everyone like?
10-01-2018, 08:23 PM | #18 | |
Rep 256
Drives: '17 F15 MSport
If youre going to bother pulling the door panels off to replace the speakers, you might as well add the dynamat as was previously suggested. That probably made a bigger impression on me than the speaker upgrade. I covered the inside of the door panels and it wasnt all that difficult to do. And, the BAVSound ghost subs are a decent upgrade from stock, but not earth shaking. Only so much air you can move with 8 cones. Just tempering your bass expectations on that... |
10-02-2018, 02:32 PM | #19 | |
Rep 703
https://f15.bimmerpost.com/forums/sh....php?t=1041781 at least this is what I will do soon, once I figure out what harness I need to connect to HK amps |
10-02-2018, 02:41 PM | #20 |
Rep 30
I have the HK system on a 2015 x5 I recently purchased. The mids and highs are fine, but there is no low end and what is present is mushy at best. I picked up a JL 500 watt mono amp and will install it near the factory amp. Making a box to hold a Focal 10" sub in the dead space near the battery under the floor in rear of x5. ( I have the 3rd row so not a lot of room in that dead cavity space. Once you remove the plastic piece back there that makes a "storage compartment", there is more space. Also adding an Audio Control LC2i and remote bass knob in blank cube by headlight adjustment.
For about ~$600 you can get the amp, sub and LC2i, make your own box and do your own install and have everything hidden and no loss of cargo space. Just a thought to get a lot of bang for your buck since the bavsound ghost subs are about $500 and you won't get a great low end sound out of that little plastic enclosure they sit in. |
10-02-2018, 02:45 PM | #21 | |
Rep 703
https://technicpnp.com/product/hifi-...ub-harnessloc/ I didn't finish yet my current project and now I have another one...damn |
10-02-2018, 02:50 PM | #22 |
Rep 703
actually this is for HK:
https://technicpnp.com/product/logic...sub-t-harness/ |
