10-07-2018, 04:38 PM | #1 |
Rep 21
BMW X6 Turning causes RPM Jump
Hello,
I have a tuned BMW X6 35I with catless Downpipes. My questions is this. Whenever I turn left, occasionally the rpm is fluctuating. My usual Idle is 600 RPM. But when I turn left the rpm jumps between 600 and 900. That only happens when you start to drive off and have to make a left turn right away like in a parking lot for example. Turning right does not seem to be a problem. I know your steering pump is working and its normal but I was wondering if having an ECU tune + Catless DP's cause the more abrupt RPM jumps. No codes and the car otherwise seems healthy P.S. The RPM surge while turning left seems to be only occasional. Thank you |
10-12-2018, 04:21 AM | #2 |
i'm just saying
5764
Rep 2,634
well seems it happened after taking the cats off, if i were you i d search for the logs of the car assuming the sensor on catless downpipe is working properly.. yes some faults not appear on dash but the car records them.. if nothing seems.. then start from the places where can hurt while changing the downpipe.. maybe some of the things over there is causing those idle differences.. if your rear wiper wont work sometimes it affects somewhere totally different on BMW's.. needs step by step inspection..
10-12-2018, 10:18 AM | #3 |
Rep 19
who tuned it, and what software did they use? it seems like they may have changed a parameter that should'nt have been changed. Flash your original file then see if it continues to do it. you can always reflash your tuned files. also was the tune done locally, was it done while driving or on the dyno?
10-24-2018, 07:51 AM | #4 | |
Rep 21
