10-27-2018, 07:50 AM | #1 |
Long Time Bimmer Fan
215
Rep 156
Squeaky & Noisy Armrest Fix
I have found a cheap and decent fix for those squeaky, noisy arm rests. Mine got so bad that it would squeak with the slightest amount of arm pressure on it. I couldn't take it anymore and had to figure something out and have found a fix. I've been on this fix for a few months now and it has killed 95% of the squeaks and should cost you less than $5 and 5 minutes of your time. Seems to be holding up very well so far.
I used 2 strips of closed-cell sponge rubber tape (Home Depot) and placed a strip at the front and rear top edges of the box so that the 2 arm pads sit on top of the sponge tape when you close them. Note: for the first few days, it will feel tough to close the arm rests but the tape will eventually settle (after a couple of days) and it will work like normal but without the squeaking. Tape Dimensions: 3/8" (9mm) Wide 3/16" (5mm) Height I think you guys should find this a pretty useful fix...good luck and let us know if you run into any challenges or have better ideas.
2014 X5 XDrive 35i - Current
2010 X5 XDrive 4.8iS - Traded 1990 325iS - Sold 1985 318i - RIP |
10-27-2018, 08:23 AM | #2 |
Rep 366
I am going to do this today. With felt, instead of the foam tape.
EDIT: Yours is different than ours, and I don't have those raised areas where you applied the tape.
2014 X5 35d X-drive. Space Gray Metallic. Mocha Dakota Leather.
10-27-2018, 09:24 AM | #3 | |
215
Rep 156
I cut 2 full length strips, about 6.5" in length each, and placed one across the entire length of the front and the other strip across the entire length of the back section...hope i'm making sense. If it helps any, here is a pic of mine pre-foam install.
2010 X5 XDrive 4.8iS - Traded 1990 325iS - Sold 1985 318i - RIP Last edited by A-4WD; 10-27-2018 at 09:31 AM.. Reason: to provide further clarification |
10-27-2018, 09:33 PM | #5 | |
Rep 366
His reply cleared things up.
