11-04-2018, 05:16 PM | #1 |
Rep 2,388
Just a quick front bumper swap to M Sport one
Had front M Sport bumper laying for a couple months and decided to do it today on the Home Depot parking lot. For those looking to swap non M Sport to M sport - it can be done without any extra parts, but if you go by the book you'll need 2 air ducts for M Sport (they are a bit different), but I did it without them. Just managed to use old air ducts.
Fog LEDs, front view camera and 4 parking sensors are just plug-n-play - you unclip them from old bumper and clip to a new one. So total it's 5 torx bolts on top, 2 torx at the connection to fender at sides and 8 bolts from below the bumper. I spent 2 hours, but as usual if I had to do it again - I would do it in 20min. The bottom portion of M Sport bumper still needs 4 bolts - that's why it's sticking out a bit. I'm going to fix that soon, just ran out of time - had to do other things. It's indeed looking a lot better in person (don't pay attention to dirt - bumper was sitting on balcony and AZ storms covered it with dust) when you have M Sport. For everyone on the fence I highly recommend it. Last edited by DuSh; 11-04-2018 at 07:26 PM.. |
11-05-2018, 02:06 AM | #5 |
Rep 2,388
Yeah man, it's a hard color to match. Hopefully fingers crossed it's going to look amazing. I was lucky to buy a used M Sport set already painted my AW color. If it wasn't for that - I would have probably never done M Sport conversion - just due to $$$ required to do it right. I did both bumpers and next step will be side skirts (but I need supports for them and they are $100 each - for the plastic part that no one will even ever see). Then aero kit on top of that for m sport. It just never ends
Russmov1328.00 |
11-05-2018, 02:56 PM | #10 |
Rep 2,388
11-05-2018, 05:12 PM | #13 |
Rep 2,388
Yep. I made sure to be on far end of parking lot to not bother anyone. Front bumper cover fits into x5 and I drove to nearest Home Depot - just in case I'll need some tool or fastener.
The thing is people think it's hard or is a huge task. The reality is that it's a bumper cover (btw it's very light - you can hold it with 1 hand - probably 10-15lbs or so) that attaches to the car with 9 torx bolts and 8 regular bolts. Only 4 of those are hard to reach, others are very easy to undo. After that it's just careful pulling cover off and disconnecting sensors. All sensors and camera are just clip on/off type of thing - very easy to disconnect. Fog LEDs have 2 bolts each. Everything is relatively easy-ish, except when you are doing it first time - it's still a challenge, but halfway into it you realize it's very doable. Tools required are a torx set and 10mm socket (if I'm not mistaken) - that's all you need. Well you can also use a plastic prier tool to remove couple fender flair rivets (or just regular flathead screwdriver can do that job also). But most importantly it's a mod bug that was giving me motivation lol. I'm sure as a lazy person I would have never even thought to accomplish something like that if not for urge to mod. Last edited by DuSh; 11-05-2018 at 05:17 PM.. |
11-05-2018, 09:25 PM | #15 |
Rep 11,145
I personally would have done this at a Neiman Marcus. With a hidden camera, naturally.
11-06-2018, 12:46 AM | #16 | |
Rep 2,388
Well, I was at the very end of parking lot, and I always keep space around me clean and tidy, but I still got couple folks driving by thinking I was crazy dude destroying a nice BMW SAV. There was a 18 wheeler truck dude chilling in his truck near me and I think he had a nice free 2hr show of how to convert non M Sport x5 to M Sport one. It was either me or just looking at the boring scenery. I think he was entertained. I think he can't complain. |
P111591.50 |
11-06-2018, 08:08 AM | #17 |
Rep 5,066
Actually doing it at home depot is brilliant... just in case you need a tool or missing fasteners.. Now doing it at Advanced Auto Parts or Autozone would have been pure genius Looks good Dush, but I would definitely remove the side running boards and add the proper Msport skirts.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
DuSh2113.50 |
11-06-2018, 10:31 AM | #19 | |
Rep 2,388
11-06-2018, 10:42 AM | #20 | |
Rep 2,388
Then it's just matter of unclipping all sensors and camera carefully and bumper cover is completely off. Once it's off - you can easily remove fog LEDs (each is held by 2 torx bolts). Also, once cover is off - it's very easy to do any trim adjustment or some other things like installing a multi-horn (as stock horn is exposed right there). It's also a good time to clean radiators if needed from dirt etc. Also, both radiators (main and extra one for 50i) are exposed with their hoses - so probably a good time to easily flush coolant if needed. BTW parking sensors are plug n play, but 2 side sensors have a bit different socket angle for M Sport, so I had to improvise to clip them on (non m sport sensors have longer wiring clip that gets in the way). |
