11-28-2018, 12:08 PM | #1 |
Rep 6,673
Buckugly Calipers + Hub + Rotors
What's a guy to do!
Are there any drilled rotor options for the 19/20 inch wheels? Paint the calipers? Thanks guys! 2015 xDrive50i M Sport . |
11-28-2018, 01:20 PM | #2 |
Rep 2,388
Easy solution is to get drilled or slotted rotors - same size, no need to upgrade to MPBK or Brembo. And then just paint calipers with caliper paint or any VHT paint. Other paints could work too. You'll get better looks without upgrading stopping power.
Then you can change pads to more aggressive bite ones like Hawk pads. This will increase a bit your stopping performance (you'll wear pads/rotors a bit faster in return). There are other options, but it will require $$$ - changing rotor/caliper size etc. P.S. Poor mans option is to just paint calipers and call it a day. |
11-28-2018, 08:49 PM | #4 |
Rep 846
Agreed with all. Paint the calipers. and possibly hubs
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
DuSh2113.50 |
11-28-2018, 08:50 PM | #5 |
Rep 714
Drives: BMW X5 M Sport - G05
Mine don't look like that...
11-28-2018, 09:37 PM | #7 |
Rep 7,164
Drives: F90 M5 / F15 50i
Several threads covering this with options. Including what I did which was take a myriad of metal Brissled bits on my drill to get all the rust off the hub and bolts back of rim and caliper. Then painted them all and then clear coated to include inside the knuckle which I'm sure looks worse than even your pictures and the inside is the rim hubs to prevent that rust from damaging the clear coat as is common with oem rims
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
DuSh2113.50 |
11-30-2018, 10:51 AM | #8 | |
Rep 1,497
11-30-2018, 12:02 PM | #9 | |
Rep 846
M302_imola843.50 |
