      12-21-2018, 03:51 AM   #1
chalupa2000
Drives: 128i
New starter and still no start
Replaced starter with a new unit and still no start. Went through all scenarios checked battery voltage recently replaced and checked ground wire positive wire at jumper location no error codes and settled on replacing starter... Replaced starter and still nothing. No crank just click and hum like before replacing starter. Lucky it died in the garage. Any input ideas appreciated. n51 with 130k miles
      12-21-2018, 05:26 AM   #2
juld0zer
Australia
482
Drives: Prev 135i 7DCT, Now 130i 6sp
When you say you checked the positive wire at the jumpstart post, did you cut back the heatshrink and wiggle the cable?
Has your car had the positive battery cable to junction box recall done yet?
Dackelone10615.50
      12-21-2018, 07:27 AM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Sometimes a "new part" does not mean it's a "good part"!
Where did you buy the part? Was it rebuilt ? I bet it was...
Did you measure the voltage AND ground @ the starter. Anywhere else does not count.
Dack
      12-21-2018, 10:39 AM   #4
chalupa2000
Drives: 128i
Starter is a new tyc sourced from Amazon. The positive cable was on tight I tried to pull it off but didn't budge unscrewed the 13 mm bolt to examine cable looked good I'll cut back the sheath just to make sure
      12-21-2018, 10:42 AM   #5
chalupa2000
Drives: 128i
I'll measure voltage at starter...where is the positive wire at junction box and how can I check
      12-21-2018, 10:01 PM   #6
chalupa2000
Drives: 128i
Voltage at starter is 12.5. All fuses look good disconnected the ibs as well. The only other thing that I can think of checking is the trigger wire that attaches to the starter. I don't think it's junction box since I get power to all accessories any other ideas I'll prolly drop off my old starter to autozone and test
      12-22-2018, 07:34 AM   #7
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Check to see if you can spin the engine by hand. Get a socket on the front crank pulley and see if it turns.
      12-22-2018, 10:33 AM   #8
chalupa2000
Drives: 128i
Since old starter was out Went to autozone to test it and it tested out OK leads me to believe new starter is good voltages check out at alternator as well... I think it's not getting the trigger signal for some reason new clutch pedal switch as well...
      12-22-2018, 09:41 PM   #9
guslealisla
Drives: 2011 135I MSport Vert
+1
When I got a spun crank bearing we were able to determine it by this method. Try this just to ensure you are going down the correct route. If it doesn't turn freely there is likely another problem
2011 135I MSport Convertible DCT. PS1,FBO,JB4 W/BEF.
      12-22-2018, 10:54 PM   #10
chalupa2000
Drives: 128i
Was able to determine or guess that the starter wasn't getting signal... Not sure of the cause... coded out starter safety checks and starts every time now.... Must be a sensor somewhere getting hung up... Just glad I'm mobile again
      08-19-2020, 08:37 AM   #11
wheelieguy
Drives: 135i 328i
possibly a bad key fob or dead battery in key fob
      08-19-2020, 01:22 PM   #12
MightyMouseTech
4338
Check the ground near drivers side engine mount?
Check the power cable from the junction point on the passenger side near the firewall?
1addicts
