12-28-2018, 07:23 PM | #1 |
Rep 264
XDrive Summer tires ok in Local Cali Mtn's i.e. Mammoth or Tahoe
I have a XDrive 50i MSport with summer tires, will I be ok going to the local mountains of Mammoth or Tahoe? Was thinking of getting chains or snow socks until I can get a set of 18"/19" for those winter trips. I wouldn't drive up while raining/snowing or during a storm. I plan on switching to A/S when these summer wear out.
2015 F15 XDrive 50i MSport
12-28-2018, 07:59 PM | #2 |
Mmmmm…
1152
Rep 2,426
Drives: F15
In the wintertime? No it's not okay. If there is any snow or ice you'll be sliding all the place with any whiff of the throttle. Tap on the brakes, you're sliding. Snow socks might be fine in snow, but you'll destroy them on bare roads (which might have ice). Chains won't do much unless you buy two pairs, which will suck for driving.
This is all from personal experience heading up to Tahoe for two years. At minimum have all season tires.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
Falafel Combo3775.00 |
12-29-2018, 04:19 PM | #5 |
Rep 6
12-29-2018, 04:49 PM | #6 | |
Rep 7,554
There are 18 " wheels & winter tires offered...and there is also supplemental info in the side columns that will reveal if you can use the 18" wheels/tires or not. I believe if you have the performance brake pkg (option code SZP1a)...then you can only go down to 19" wheels/tires. Hopefully you've decoded your VIN and know your option code list. For example, here's one of the 18" winter wheels for the f15 X5...click the link and scroll down to the part number index...check the supplemental info for the 18" wheels...see if your option codes are listed for yes or no to determine if you can mount an 18" wheel:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-30-2018 at 07:26 AM.. |
12-29-2018, 09:00 PM | #7 |
Rep 549
Summer tires are never okay in wintery conditions.
Getting the car in motion is a challenge, but the real danger is stopping. Don't do it. (In Germany, if you're caught with summer tires in winter conditions, you get a very hefty fine.) |
12-29-2018, 11:14 PM | #8 | |
Rep 979
19” rims are required for the 50i
2011 E92 M3 | JEREZ BLACK | EXTENDED BAMBOO NOVILLO | EXECUTIVE PKG | M-DRIVE | EDC | M-DCT
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts |
12-30-2018, 07:31 AM | #9 | |
Rep 7,554
The thing to know is...how is your 50i optioned? In some markets, all 50i models may be optioned with the performance brake pkg as standard...but in other markets it may be an ala carte option. Click the link to the part database in post #6 above for verification.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
12-30-2018, 08:43 AM | #10 |
Rep 1,201
Summer tires are NOT ok in Tahoe or mammoth even without snow as they lose most of their reactions below 40 degrees. Driving through the mountain windy roads at freezing temperature may mean you kill yourself and family by not being able to brake and falling off a cliff.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
12-30-2018, 10:20 AM | #11 |
Self-Deprecating Narcissist
7266
Rep 6,561
Nope. Any money you save on not buying winter tires now will be given back several times over in body repair and increases of insurance premiums. In addition you're a huge risk on the road and a danger to others. Do the right thing and equip your vehicle properly or get a winter beater and use that.
12-30-2018, 09:48 PM | #12 |
Rep 264
Thanks all! I just checked and can slap the 18" 446's on my 50i. I'll probably just look for a used set and mount winter rubber for trips to the mountains or go with either the Toyo Proxes ST III's or Conti DWS 06 when it's time to get new tires. I guess I wont be driving to Mammoth or Tahoe in the 50i this season.
12-31-2018, 11:28 AM | #13 | |
Mmmmm…
1152
Rep 2,426
Drives: F15
Then there was whiff of snow that night like there was some specks on the ground and I was tasked with going to the local market for some alcohol and meats. I'm driving nicely around 25 MPH all of sudden I find myself understeering around a bend. I've lost traction before, but there was no F'ing way to get those tires to get grip. Fortunately in front was dirt and gravel clearing not trees. I dreaded driving the car after that, but I eventually got back to the house [we rented]. I think it should have been 15 minutes, took me an hour. My friends were bewildered, but not mad. I told them what happened. The drive back was worse. That evening it was heavy stuff. CHP issued R-2. So I'm thinking we're screwed, not getting home tonight. I tell my friends they are confident in my driving (thanks!), but I tell them it'll be slow until we are out of the mountains. I drive behind another X5 (E70), they're checking cars one by one. I see the CHP guys checks his tires and let the other car go; when I drove up, I rolled down the windows, I told the officer, "Yes sir four wheel drive, snow tires, chains in the trunk, just like the same car in front, we're together." Worst case we need to find a hotel for the rest of the night, but the guy say lets us go! You think that's great I got lucky, but honestly the rest of the drive, I was so nervous. I think I drove at 10-15 MPH for 4 hours because any faster I was sliding. It wasn't fun at all. Finally out the mountains I was able to pick up some pace. Please don't make the same mistake I did. Not worth it.
BMW CCA 509766 |
12-31-2018, 01:29 PM | #14 | |
Rep 1,434
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport |
01-01-2019, 07:21 PM | #15 | |
Mmmmm…
1152
Rep 2,426
Drives: F15
BMW CCA 509766 |
01-01-2019, 10:45 PM | #16 |
Rep 3
I just called off a trip up to San Bernardino Mtns (Snow Summit) for this exact reason. Summer tires on my Msport 50i. Going to buy a set of Continental all seasons. I have rear tire chains. There is not sufficient clearance for front chains, even cables.
I have lived in California all my life. Never really considered the limitations of summer tires. Doing some research it seems really dangerous to drive with Summer tires in cold weather (below 40) let alone in snow. What do people do with non run flat tires? |
01-18-2019, 01:04 PM | #18 | |
Rep 100
AAA and an new OEM spare off ebay for $239 in case of emergency |
01-19-2019, 09:22 AM | #20 |
Rep 272
What brev said! The summer rubber is very soft to enhance grip. In the cold it hardens and can lose grip even on dry pavement.
My set-up is full winters on 19" 467's. Have run flats in the winter -- I hate changing tires in the cold/snow and will swap to conti non-run flats when my OEM tires are gone -- I already have the plug kit and 19" space saver spare ready to go.
Duke
2018 X5 50i 2015 911 C2S 2017 X4 M40i (gone); 2010 X5 (last of the NAs); 2007 550i (still missed, except in the snow); 1991 525i manual (great 17-year run) |
01-19-2019, 09:59 AM | #21 | |
Rep 6,673
