12-30-2018, 02:45 PM | #1 |
Rep 872
FS: Turner E9X Aluminum Undertray
Purchased new in late October 2018. Finally found time to install this weekend and discovered my SC intercooler piping prevents installation of the passenger side support bracket. Kinda pissed about that, but my fault. Willing to ship at my expense. $500 OBO.
AA Gen 2 Lvl 2 w/Meth; MagnaFlow catless x-pipe; Dinan Underdrive Pulley; VAC Coated Bearings; ARP Rod Bolts; Oil Diverter Valve; Dinan Strut Braces; Dinan Rear Toe Links; ECS Rear Trailing Arms; MCS 2-Way NR w/700F-1000R; GC Camber Plates; AKG 75D MM & 95A TM; CAE Shifter; Titan T-S5; StopTech ST60 380mm/ST40 355mm; MFactory DS; Zebulon Splitter; Zebulon 330 Rear Wing; Gutted w/Piper Motorsports Custom Cage; OMP WRC-R Seats
12-30-2018, 05:15 PM | #3 |
Rep 872
12-31-2018, 05:58 AM | #5 | |
Rep 872
Thanks for the plug!
12-31-2018, 07:18 PM | #7 |
Rep 872
Suppossed to be in the 15-18 lb range. I was suprised at the weight. However, the two suport brackets are very solid.
01-01-2019, 07:19 AM | #9 |
Rep 872
I think it will but can't say for certain. It's suppossed to slide into the bumper cover exactly like the stock part, but it is thicker and has no "give" to it. Probably will depend on your lip and how far back it extends. You need to be able to access the three holes on the underside of the cover to secure the cover to the undertray.
MilehighM3915.00 |
01-07-2019, 01:18 PM | #10 |
Rep 531
I installed mine without using their support brackets and just re-used the OEM steel cables. I didn't want undertray impacts transferring directly to the frame, but obviously install it that way at your own risk.
Boston BMW CCA Autocross ///408 E90 M3 |
