12-30-2018, 06:42 PM | #1 |
Retired Curmudgeon
2995
Rep 4,067
'16 40e, stock 20" RF wheels touching upper control arm
So I have less than 20k miles on my 2016 40e.
I moved to a new place and now have to go full opposite left lock on the steering wheel to get out of my parking spot. I started to hear metal on metal grinding noises so I pulled the wheel. I was more than a bit surprised to see the inner lip of the wheel paint was scraped all the way around. Looked at the upper control arm and it had a mark on it where it was clear the wheel was touching it. Checked out both L&R tension struts and the bushings have hairline cracks but nothing tragic looking. Control arm bushings looked good too. No noticeable play in the wheel (e.g., loose wheel bearing or other part). Remember, this only happens on full left opposite lock. Tempted to get a thin set of spacers (or avoid opposite lock and do a multi-point turn instead...). Thoughts?
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS Last edited by admranger; 12-30-2018 at 09:44 PM.. |
12-31-2018, 11:40 AM | #2 |
Mmmmm…
1152
Rep 2,426
Drives: F15
With stock tires, that shouldn't be happening. I would put her on a lift and have it looked at. That hairline cracked bushing might be totally apart inside.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
12-31-2018, 11:43 AM | #3 |
Retired Curmudgeon
2995
Rep 4,067
I had it up on jack stands last night. Bushing was flexing, not fully torn.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
12-31-2018, 09:25 PM | #5 |
Retired Curmudgeon
2995
Rep 4,067
Thanks for the suggestion. I think if it were out of range I'd get an error on the steering angle. However, I will look and see what's there.
01-20-2019, 08:01 PM | #6 |
Retired Curmudgeon
2995
Rep 4,067
Ok, so I have a resolution of this issue...kind of anyway.
After staring at the suspension bits for about 30 minutes, calling my wife out to look at them as well (both engineers), we went back to first principles. This started immediately after having the tires balanced and rotated. You can see where this is going, right? Yes, I swapped the front wheels back to their original positions and the problem went away. I have no idea how this works, but I don't care as the car is a lease and it gets turned in to BMW in July. FWIW, this isn't some small 1 or 2 mm change, it's a 5mm change in wheel to upright distance. Really, really odd as all the suspension members look to be in great shape and measure the same R to L pivot point to pivot point. Wheel rubs all the way around so it's not bent unless it's been shoved in uniformly across its entire circumference.
01-20-2019, 09:33 PM | #7 | |
Rep 651
All OEM 20" wheels for the 40e, have different offset, front and rear. 10JX20 ET:40 11JX20 ET:37 If you installed a rear wheel up front, it is a 1" wider rim, or .5"(12.7mm) on each side, and the offset is another 3mm different Inside edge is about 10mm further in. (phew, too late to try to think about offsets etc. believe I got it correct now) Last edited by 1norseman; 01-20-2019 at 09:55 PM.. Reason: corrected the distance |
01-20-2019, 09:41 PM | #8 | |
Retired Curmudgeon
2995
Rep 4,067
01-20-2019, 10:03 PM | #9 | |
Rep 651
Your issue for sure is a weird one... |
01-21-2019, 07:32 AM | #10 | |
Retired Curmudgeon
2995
Rep 4,067
I'm the king of weird issues lately it seems. Some car related, most not.
Russmov1328.00 |
01-21-2019, 07:27 PM | #11 | |
Rep 651
Weird issues makes life interesting sometimes. Hope most are interesting ones for you, and not just without a good explanation like this one... |
admranger2995.00 |
