01-12-2019, 05:03 PM | #1 |
Rep 95
Paint Correction - stage 1
So anyone who knows about machine polishing, it's not a quick job.
So today was "hood day". Washed, clay barred - just the hood. Then medium abrasive polish on a light cut pad with my PC DA. 2 passes over each area (8 sections across the hood). Followed up with a nice Natty Blue Wax - left to sit for 15 minutes before buffing. Picture and a couple of vids in the link below. https://photos.app.goo.gl/88bmeXCGZtgVhAdT6 Hood is definitely the biggest area to do, so the front fenders and front doors are next, maybe next weekend.....maybe tomorrow
2014 X5 50i M Sport - Carbon Black
01-12-2019, 10:05 PM | #2 |
Rep 11,145
All that lovely polishing, and then you top it with Natty Blue? I had a pot of that in my very first detailing order I ever placed, must be a good ten years ago. I think that wax lasts two days. Do yourself a favor and get a nice sealant. You'll thank me!
johnhol96.00 |
01-13-2019, 12:09 AM | #4 |
Rep 95
Wolfgang sealant 3 being delivered tomorrow 😁
Seems I'm too old school.....let's see what this turns out like. Will be doing the fender and front doors tomorrow so will finish it off with the sealant.
P111590.00 |
01-13-2019, 08:04 AM | #5 |
Rep 272
Try Jescar Powerlock sealant topped with Colonite 845 someday. Great combo, easy to apply and lasts.
Good luck with the black! Ton of work.
Duke
2018 X5 50i 2015 911 C2S 2017 X4 M40i (gone); 2010 X5 (last of the NAs); 2007 550i (still missed, except in the snow); 1991 525i manual (great 17-year run) |
01-13-2019, 08:50 AM | #6 |
Rep 95
Thanks, yeah it will be a lot of work. But once you get it done....easy to keep it look great. I just need to keep it out of the car wash and threaten the dealers if they offer a "free car wash"....lol
Russmov1328.00 |
01-13-2019, 11:53 AM | #7 |
Rep 277
When I first got my x5, it wasn't in the best shape paint wise. Being imperial blue in the north.
I started with a heavy cut with a wool pad, to a orange pad medium cut, and to a polish and yellow pad. I was afraid to do the whole car with the heavy cut without a gauge so I only did the worst areas. Now since HD one has came out, I use HD one with an orange pad, HD speed with an orange pad, and Hd Poxy with a white pad. I have been more then happy with the HD product line. That combo has last about 3 months so far. When I have a warmer day I ll do the speed and Poxy again. |
P111590.00 |
01-13-2019, 01:01 PM | #8 |
Rep 11,145
01-13-2019, 09:04 PM | #9 |
Rep 272
Same here, it is so great. So glad I found it. Try topping with the 845 sometime.-- similarly easy to use -- extends the life, enhances the slickness. D
Duke
01-13-2019, 09:16 PM | #10 |
Rep 11,145
I have 845, and it's not as easy to apply and remove as Power Lock. You have to go REALLY thin on the 845. The Power Lock is a bit more forgiving.
01-14-2019, 06:37 PM | #11 | |
Rep 76
Could somebody break down what is needed from start to finish and what products to use when? Sounds like wash, clay bar, then what pads/compounds? I need an idiots guide to detailing a black car. First one I've owned. |
01-14-2019, 07:22 PM | #12 | |
Rep 11,145
My pads are all Detailer's Domain pads. My polishes are all Menzerna. Sealants, I use Power Lock. My waxes are mostly high-end Swissvax. Spray wax is Optimum Instant Detailer. |
01-14-2019, 08:21 PM | #13 | ||
Rep 76
01-14-2019, 08:25 PM | #14 |
Rep 938
all menzerna polishes here too. johnhol you may want to add one more step.. sorry! medium to a polish is too harsh, i prefer to go to a fine polish after medium because it truly removes swirls. rule of thumb is always work your way down from whereever you started. sometimes you can use a softer pad instead of a different polish, play by ear to see how the paint responds.
this is my process: 1. wash with dawn or dish detergent to cut wax off 2. clay bar with soapy water 3. depending on damage, start with menzerna SI 1500 (I may even go with a fine cut polish if its rough) 4. menzerna SF4000 5. p21s paint sealant (acts as a super fine polish) 6. wolfgang 3.0 sealant (you can stop here, the wax is purely for depth at this point) 7. p21 pure wax (ive found it to be best bang for the buck) |
BimmerTy195.50 |
01-14-2019, 08:42 PM | #15 |
Rep 11,145
01-14-2019, 10:21 PM | #16 |
Rep 625
Been lazy lately and been using the FG400 on purple wool pad combination. It is quite dangerous for a novice user especially on corners and ridges of the X5 but can produce great results if used correctly.
It does produce some hazing which can be corrected mostly with SF4500 on black foam pad. Been using Menzerna Power Lock for 5 years now and I just finished a bottle and that was $32 for 5 years (I did use Einszett 1Z Glanz wax when I have the time)... I laugh at people spending hundreds on "ceramic" coating... |
01-14-2019, 10:25 PM | #17 | |
Rep 3,742
Another vote for Jescar Powerlock Sealant which was formerly.. https://www.detailedimage.com/Ask-a-...with-pictures/ All my products these days consistent of Gyeon. Amazing products with outstanding results as well as durability. If needed I have a Rupes Mark II Bigfoot 21 and PC to tackle issues, swirls and marring which both are totally avoidable with proper handwashing. A foam cannon certainly helps as well... Last edited by SCA; 01-14-2019 at 10:36 PM.. |
P111590.00 |
01-14-2019, 10:41 PM | #18 | |
Rep 11,145
01-15-2019, 06:44 AM | #19 | |
Rep 95
It's a medium/light compound, but with the clear coat on a BMW (and most german cars being so hard, light/fine never gets the level of correction I needed. I know if you don't break in down enough you'll get marring but thankfully in the cooler temps at the moment, the "play" time with the polish is longer so corrects well, and then gives a nice finish. I'll be doing the front half of the CB on Saturday (unless the wife has plans), so I'll try and get some more 50/50 shots/videos. Also I've got my sealant as well so I'll see how that compares to the wax option.
01-15-2019, 06:53 AM | #20 | |
Rep 95
Ideally, you want to wash your car (have 2 buckets with grit guards and some clean wash mitts - 3 would be good....one for hood and roof, one for top half of the doors and rear, one for bottom half of the doors.) One bucket with soapy water, one bucket with clean water.... Once you gone over a small area with the soapy mitt, dunk and rinse in clean water, back into soapy...and so on. I will caveat the above by saying I foam lance with Chemical Guys snow foam, leave to sit for 10 minutes then power wash off, then repeat. But that's just me Then I dry with 2-3 drying towels. spierce At this point you have 2 options.... Machine Polish or normal polish You can get hand polish that is ok, if the paint looks good then machine polishing might be excessive....especially if you don't own one already. I'd take a look at detailingworld.co.uk as they have videos and guides on what to do... I've always used wax, but after a comment above....I felt old so went and bought some sealant.....so I've reserve comment on waxes vs sealants...
01-17-2019, 12:09 AM | #21 |
Rep 192
So do I need to clay bar the car if I'm going to use a polish with yellow pad on a buffer?
Next week I plan to wash the car, dry it with my air blower to get most of the water off, then dry with my new waffle microfiber towels. I was planning on doing the yellow pad polish next, followed by the white or black pad with PowerLock. Does that sound ok or do I need a clay step in there? |
01-17-2019, 02:49 AM | #22 | |
Rep 1,343
Drives: 2015 BMW X5 xDrive 35i
2015 BMW X5 xDrive 35i-Current
2016 BMW X4 xDrive 28i-Sold 2014 Lincoln MKX-Sold |
Localbrew145.00 |
