01-15-2019, 08:00 AM | #1 |
Rep 788
Busted Wing Mirror!
So yesterday I noticed that someone had hit my wing mirror causing damage to the outer trim
Fortunately neither the front cover nor the mirror were damaged. Anyone know whether I can replace the damaged trim rather than the whole mirror? Bearing in mind I have a camera located in the mirror what would be the cost of replacement? Cheers
Old Wheels - X5M50d in Carbon Black
New Wheels - X7M50d in Phytonic Blue |
01-15-2019, 08:20 AM | #2 | |
Rep 1,343
Drives: 2015 BMW X5 xDrive 35i
Anyways OP, sorry it happened to you. That definitely sucks.
2015 BMW X5 xDrive 35i-Current
2016 BMW X4 xDrive 28i-Sold 2014 Lincoln MKX-Sold |
01-15-2019, 08:26 AM | #3 | |
Living the dream
4588
Rep 2,194
Drives: X5 w/MPPK, MPE & RC GTS Black
Russmov1328.00 |
01-15-2019, 08:40 AM | #4 |
Rep 788
[QUOTE=Russmov;24241326]That is such an odd place for it to be broken. I'm curious as to how that happens.
Anyways OP, sorry it happened to you. That definitely sucks.[/Q The mirror was forced back against the side window resulting in the trim catching where the mirror pivots - hence the corner being damaged. Certainly unusual especially with the cover and mirror being in one piece.
Russmov1328.00 |
01-15-2019, 10:01 AM | #5 | |
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
Not as expensive as you might think. Your mileage may vary.
01-15-2019, 10:17 AM | #6 |
Rep 788
Thanks DeeO
So in old money terms that's £50 + £150 labour Wonder how easy it is to do myself?
01-15-2019, 10:46 AM | #7 | ||
Rep 1,025
01-15-2019, 08:28 PM | #8 | |
Mmmmm…
1152
Rep 2,426
Drives: F15
Yes, it's actually very easy to fix.
1) Adjust the mirror to make it easier to pop off, unplug heating element and auto-dimmer plugs (the mirror literally is just pull to remove, just don't drop it) 2) Pop off back cover (the part facing forward that is painted) 3) Remove screws on bottom half of mirror 4) Remove bottom half of mirror that also includes the mirror surround that is broken in your picture, and unplug blind spot and camera 5) Transfer turn signal and camera to new piece; the camera can only be inserted on way, it is keyed. 6) Reverse to install I cracked both sides, one side I hit a wall when my car was new, the other got hit by a bus and actually smashed my turn signal as well, my mirror housing folding in so much past the post of normally folding that it actually hit my glass and it cracked the housing like yours. First side took me about 10 minutes (with the turn signal), but once I figured it out, the other side took me 3 minutes. Quote:
2015 BMW X5 xDrive50i
BMW CCA 509766 Last edited by alphaod; 01-15-2019 at 08:40 PM.. Reason: Clarified some instructions |
foo200261.50 |
01-16-2019, 03:10 AM | #9 | |
Rep 788
So I don't need to take the whole mirror housing off from the inside pillar of the car? How much force do I need to remove the mirror from the housing - does if just pop off? I assume the mirror needs adjusting to be able to get a decent finger hold on the edge to pull it out?
01-16-2019, 11:10 AM | #10 | |
Rep 984
Tilt mirror all the way up. Pull it up and out from the bottom. All screws are accessible at this point. I did not need to remove the front cover, but mine was shattered a lot more than yours. |
01-16-2019, 05:00 PM | #11 | |
Mmmmm…
1152
Rep 2,426
Drives: F15
BMW CCA 509766 |
