02-16-2019, 04:28 PM | #1 |
Rep 618
ecs spacer issue
hello I order some spacers for the car m3 e92 15mm front 12mm for the rear but now the front end vibrate which didt have before the spacer they look well made good quality hub center and I did the install everything was done right have anyone had any issues with this spacer
02-16-2019, 04:46 PM | #2 | |
Rep 1,216
2011.5 E90 M3
LeMans Blue |
02-16-2019, 04:51 PM | #3 | ||
Rep 618
02-16-2019, 04:54 PM | #4 |
Rep 180
You're also adding leverage to the front, the extra force may be enough to feel an imbalance in your wheel/tire setup. If you can't sort it out with playing with the spacers, try that. I had issues with OEM ZCP wheels vibrating with spacers, aftermarket wheels were fine.
02-16-2019, 04:56 PM | #5 | |
Rep 618
02-16-2019, 05:00 PM | #6 |
Rep 142
Keep us posted..I was a click away from purchasing the same set spacers from ECS. I have the stock OEM set up myself.
QUOTE=nekbreaker;24390984]hello I order some spacers for the car m3 e92 15mm front 12mm for the rear but now the front end vibrate which didt have before the spacer they look well made good quality hub center and I did the install everything was done right have anyone had any issues with this spacer[/QUOTE] |
02-16-2019, 05:05 PM | #7 | |
Rep 618
I will mess with it tomorrow and see if I can get that fix but ecs stand behind their product I already contacted them on the issue I will try the turnermotorsport brand and see what happens not before trying to get it right with this 15mm ecs set lol |
02-16-2019, 07:39 PM | #8 |
Rep 1,216
I've had 6 different sets of ECS spacers and until I figured out I needed to turn them to fit the hub, they vibrated. Also a set from h&r did the same
2011.5 E90 M3
LeMans Blue |
02-16-2019, 08:25 PM | #9 |
Rep 3,140
Drives: 2014 M5 6MT
use a wire brush to clean the hub and matting surfaces. then apply a light coat of anti seize and install the spacer. turn the spacer a few times on the hubs to set them. install the wheel and torque with minimal weight on the tire. ( let the jack down just enough so the tire touches the ground).
2014 M5 6MT
02-16-2019, 10:07 PM | #10 |
F15 daddymobile
2353
Rep 3,519
Another spacer vibrates thread. Do people not know how to search google?
02-16-2019, 10:47 PM | #11 | |
Rep 618
02-16-2019, 10:49 PM | #12 |
Rep 618
02-16-2019, 10:55 PM | #13 | |
F15 daddymobile
2353
Rep 3,519
It's just some of these issues are all over the web if you bothered to search.
02-16-2019, 10:58 PM | #14 | ||
Rep 618
02-16-2019, 10:59 PM | #15 | ||
Rep 618
02-17-2019, 02:33 PM | #16 | |
F15 daddymobile
2353
Rep 3,519
I've ran spacers from ECS, TMS, MS, H&R, and a no name brand. All have performed the same. The only time i've experienced vibrations was due to not properly torquing down the wheel evenly.
02-17-2019, 04:28 PM | #17 | ||
Rep 618
02-17-2019, 04:37 PM | #18 | |
Rep 618
02-17-2019, 06:57 PM | #19 |
Rep 2,738
Turner Motorsports spacers is what I have that caused an issue on my car. With my Apex Arc 8 wheels they caused a wobble on both sides. This is with lugs torqued with craftsman torque wrench:
I had to grind the spacers all around the center. They had a chamfer there that didn’t mate correctly with the inside of the wheels. This is what I did: This is how the wheels run now: Last edited by Biginboca; 02-17-2019 at 07:17 PM.. |
02-17-2019, 07:05 PM | #20 |
Rep 618
02-17-2019, 07:08 PM | #21 | |
Rep 2,738
BTW, I installed this set up at Christmas and I had no idea it was doing this until 3 days ago. I was stopped at a red light and a guy rolled down his window to let me know my back tire was wobbling. I got out and looked all the lugs were tight and I felt nothing but I drove slowly and filmed with my cell phone out the window and sure enough could see the wobble when I watched the video. Never felt it at all and I’ve had the car over 120mph like that!
02-17-2019, 07:27 PM | #22 | ||
Rep 618
