02-16-2019, 08:22 PM | #1 |
Rep 123
Gunning it - when to not?
Long story short, my 35i with mppk and mpe is making me drive with a heavy foot and I find myself switching it to sport, and going all out. I love how you can hear the exhaust suck in the air and switch gears - the car is just a joy to drive.
Here's the question though - when is it bad to do that? I think when the car first starts up, you should give it time to breath a little but anything else I should know before doing unnecessary damage (besides to my wallet b/c of gas)? thanks |
02-16-2019, 08:26 PM | #2 |
Rep 2,534
Drives: 16 G12 + 15 F06 + 17 F15
As a rule of thumb, always ensure your oil temperature is warm and up to full operating range. Never push your car when the oil temp is cold. Its the reason the the E9x M3 and E60 M5 were blowing motors from failed rod bearings.
02-16-2019, 08:44 PM | #3 | |
Rep 1,343
Drives: 2015 BMW X5 xDrive 35i
2015 BMW X5 xDrive 35i-Current
2016 BMW X4 xDrive 28i-Sold 2014 Lincoln MKX-Sold |
02-16-2019, 09:17 PM | #4 |
Rep 2,995
Most important. Get engine up to operating temp first.
02-16-2019, 09:47 PM | #5 |
Rep 846
Never drive above the speed limit
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
02-16-2019, 10:34 PM | #7 |
Rep 58
In cold weather- remember that there are element of your suspension that never really warm up- this pertains more to driving style and road conditions- but I tend to take it easy on really cold weather- even if the engine is warm. Just erring on the side of caution in cold weather...
You may want to ensure that you are using a synthetic oil as well, if you are worried- for my money it is cheap insurance. I used 0-20 mobil 1 in my 2010 Forester turbo a few winters ago- ran fine even when it hit 60° F on a winter day. For what it's worth, I warm up for about 5 second then pull out and drive gingerly for the first 1/3 mile. I've a 2014 F15 w/ MSport, and a race chip, the first transmission shift seems a little stiff and does not 'upshift' perfectly smooth- nothing harsh, just noticeable. I go easy for the first few miles- Perhaps use the torque meter to make sure you are not stressing anything until you want to? |
02-17-2019, 02:55 AM | #8 |
Mmmmm…
1152
Rep 2,426
Drives: F15
I always let me the oil temperatures come up then I know the block is warmed up and likely the transmission, etc. then it’s fair game. Also I don’t speed much in New York because I don’t want to deal with points on my license. I never speed in residential areas and I usually drive with traffic in town. That all said once I’m out of state I’ve hit the governor more times then I care to count. I always pull over promptly sometimes before I even see the lights.
The Libertine1237.00 HJ478.00 |
02-17-2019, 10:02 AM | #10 |
Rep 317
The owners manual states to drive slowly/moderately until engine has warmed up. I usually let the oil temp hits operating temp before flooring it.
In addition make sure your engine oil is at proper level (check level when refueling fuel), use correct oil grade (0w to 5w and 30 to 40), and when your coming close to your next oil change (@ 7500 miles) try not floor it often as oil has reduced protection level (depleting TBN/additives), and drive safe! |
HJ478.00 |
02-17-2019, 10:33 AM | #11 |
Rep 11,145
When you're out of warranty.
sbinshihon684.50 |
02-17-2019, 10:42 AM | #12 |
Rep 518
Drives: G82 M4, F15 X5, F30 328d, E30
^This!
2022///M4 Competition BSM / Fiona Red.
2023 X7 xDrive40i, BSM / Individual Ivory white/Atlas Gray over Piano Black MSport Pro and Prof. |
02-17-2019, 10:45 AM | #13 | |
Rep 1,222
02-17-2019, 01:44 PM | #14 |
Rep 174
FWIW, Tire's need to warm up, too. I'd guess that by the time the oil temperature is up the tires will be warm, weather conditions observed.
The manual gives a number like 1.2 miles under which a tire is considered cold. Tires have an operating temperature at which they perform as designed. Too cold and they don't grip as well, too hot and they abrade before they should. |
02-21-2019, 01:45 AM | #15 | |
Rep 58
Maybe i should see what openings are at BMW... |
02-21-2019, 07:50 AM | #16 |
Rep 5,066
Add Racechip to that beast now and let her rippppppp!
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
r33_RGSport13053.00 |
02-21-2019, 04:28 PM | #17 | ||
Rep 174
I'm surprised that the car manual isn't similar. |
02-21-2019, 04:56 PM | #18 |
Rep 252
Drives: '06 M3, '20 X3MC, '03 540i MSp
2020 Dark Graphite X3M Competition
2021 Audi e-tron 2006 Mystic Blue M3 2003 540i MSport 1991 Red 318i (M50B25 engine swap) |
r33_RGSport13053.00 Jase112516.50 |
