      03-06-2019, 02:01 AM   #1
Kdubs88
Drives: 2007 e90 328i
Key fob buttons not working, just bought car
Hey guys, yesterday I picked up a 135i m package 6mt. The car came equipped with comfort access, it has the removable key battery and the lines on the door handle. Anyhow, my key buttons don't work, and neither do any of the comfort features. I have to physically take the key out of the fob and stick it in the cylinder to lock/unlock.
So far I've replaced the battery to the key with a brand new one, and checked the fuses. Fuse #6 (5amp) was toast, so I put in a new one. All the other fuses were fine. Still no luck. I'm new to the e82, I've had 2 e92s and 2 e90s. I know most of the stuff is the same but what else should I be checking?
Also, on a side note is there way to calibrate the active steering with inpa? The car just got an alignment but the shop couldn't figure out the active steering. Wheels are straight and car tracks straight but the steering wheel is cocked almost 45° to the left and it's bugging me.
Thanks for any help you guys might offer!
      03-06-2019, 02:41 AM   #2
Kdubs88
Update: the car came with a new diversity antenna not installed. I just installed it and now the buttons on the keys work, but the comfort features do not. What should I look at next?
      03-06-2019, 11:28 AM   #3
Kdubs88
Bump
      03-06-2019, 11:48 AM   #4
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Check for water/corrosion in the comfort access module. In the trunk, underneath right tail light.
      03-06-2019, 11:49 AM   #5
Kdubs88
Thank you I will go check and report back
      03-06-2019, 03:49 PM   #6
atch417
atch417's Avatar
20
Drives: 2011 BMW 135i
I had this same problem on my 1 series I bought back in November. Took it to the dealer bc it was still covered and they replaced my driver side door handle (🤷*♂️), battery and did a bunch of programming on the comfort accessory computer in the trunk. Was a heafty price rag but it all works now.
      03-08-2019, 08:15 AM   #7
swunder
Drives: 135is, x3 m40i, V70R
If you picked it up yesterday you don't do anything besides bring it back to whoever you bought it from and have them fix it or reimburse you.
      03-09-2019, 04:19 AM   #8
Kdubs88
I got the car for super cheap knowing it would need some fixing. Mechanically the car is great. The seller let me know before hand what I was buying. That's why I'm here and not there asking for money back.
      04-26-2019, 02:06 AM   #9
jamespaoli
Drives: 128i
I have the same issue and cannot figure it out... May i ask the diversity antenna do you have photos or can you tell me where it was physically?
      04-26-2019, 02:08 AM   #10
Kdubs88
The diversity antenna is inside of the headliner, all the way at the back by the rear windshield in the middle
      04-26-2019, 02:36 AM   #11
jamespaoli
Drives: 128i
Thanks Kdubs, i wanted to be sure.. Yes ive replaced this and still same issue..
How is your progress on fixing this issue?
      10-24-2019, 10:02 PM   #12
Razorrx
Drives: 2009 135i and 2008 535i
Any updates?
1addicts
