07-28-2008, 08:11 PM | #1 |
Rep 5,498
Audi keeps V8 for RS4 and RS5
Interesting piece of news if true.... At what I suspect is the height of the current "fuel crisis" Audi still plans to use V8's in the RS4 and RS5. While many here speculate that BMW will go back to a six, Audi on the other hand is sticking to the eight. And without forced induction as predicted months ago....
http://www.autoblog.com/2008/07/28/a...5-to-keep-v8s/ Jason
Instagram: jellismotorwerks |
07-28-2008, 08:15 PM | #2 | |
Rep 4,021
Drives: 2008 335xi Coupe
Thanks goodness, this will force BMW's hand to stick with naturally aspirated engine for the ///M cars.
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
07-29-2008, 04:21 AM | #3 |
Rep 780
This doesn't surprise me - it would have been difficult for Audi to reliably extract the 450HP or so horsepower it needs to compete/better the M3 Coupe from a 3.0L supercharged engine.
450HP from the current 4.2L mill is certainly attainable, with the extra drive train losses it would probably put in on a par in terms of straight line performance with the M3... |
07-31-2008, 12:07 AM | #5 |
Rep 363
07-31-2008, 10:07 AM | #6 |
Rep 4,021
Next gen M's will be forced induction....it is the end of ///M
07-31-2008, 11:11 AM | #8 |
Rep 1,603
Drives: F80 M3
It may have been too late in development for Audi to change. These aren't huge volume cars for Audi, so the events of the past several months may cost more to change now. The consumer who buys these cars is less sensitive to fuel prices anyway, notwithstanding those who are stretching to buy the car in the first place.
2015 SO/SO MT M3 :: Exec : Lighting : Adaptive : HK : CF trim : Full leather : DAP : Black 19's : sunshade
Crystalline tint 40%/70% on windshield : M performance mirrors, spoiler, splitters : Status Gruppe CF lip : RKP diffuser : Fully dechromed Bavsound Stage 1 : V1 Savvy hardwired : Self-coded |
07-31-2008, 12:15 PM | #9 |
Rep 8,033
Think about how long it took BMW to develop the current NA V8 in the M3. It showed up in the E46 M3. Then a V10 version in the M5/M6. I don't see the next generation Ms having a 6 cylinder FI engine as we haven't really seen any basis for such an engine in any form. My 2 cents...
07-31-2008, 12:44 PM | #10 | |
Moderator / European Editor
1549
Rep 6,754
I know it's not opportune, but I personally would like to see an S65 derived V6 engine + DI + FI + a redline of about 8k. That would be an engine...damn, I'm dreaming... Best regards, south
07-31-2008, 04:41 PM | #11 | |
Rep 8,033
If the V10 will not fit properly and FI is a must for more power, I think they might look into an FI version of the S65 with 8 cylinders. Also, on another note, (not directed at South), FI will not result in a drastic decrease in consumption during hardcore driving. People think if you strap on a turbocharger and reduce the number of cylinders, you will all of a sudden have a much more efficient engine at all times. Doesn't work that way exactly if the engine is being used to extract lots of power. FI results in significant savings when the engine is not being pushed--when you're driving around town or cruising on the highway as you don't need the boost which makes the engine act like a larger displacement engine and gives it more power. When you get on it, the savings won't be that drastic. Take the 911 Turbo engine, or a chipped N54, and the current S65. Strap them to a testbed. Run both of them at 400 hp output and measure consumption. How much of a difference in consumption will there be?
07-31-2008, 05:14 PM | #12 |
Rep 8,027
Lucid,
You are correct FI only benefits economy when you are not on it as you put it. If they do go the FI route then small+large turbo combination could be the answer, the small unit giving little or no lag while the large one giving the top end grunt. Not so sure that 8500rpm would be on the cards, it might be possible in race mode but no use in normal road engines. Personally I would go the supercharger route, MTM have shown wih their RS4SC that 8200rpm is very possible and still prove reliable, with BMW's money such an engine would be wee buns. |
08-02-2008, 03:55 PM | #13 |
MacroRisk
109
Rep 2,523
I was thinking this too but Audi's decision will keep the pressure on BMW to retain hi-po naturally aspirated - just a hunch.
Just thinking of something not so witty ///M3 E92 '09 Jerez Black | 6MT | Ext Fox Red | Tech | Prem | 19s |Heated Seats | iPod |Smartphone | Euro Deliv June 09 Sold: 540iT / 530i / 323i |
08-02-2008, 03:56 PM | #14 |
MacroRisk
109
Rep 2,523
I wouldn't be displeased by this kind of design
08-03-2008, 03:22 AM | #17 | |
Rep 8,027
Their efforts with the 335i are without a doubt one of the best applications of the technology, equal to anything that Audi have done prior to the mighty RS6 v10 unit and the latest 997turbo. But to be perfectly honest a 3.0L bi-turbo producing 300hp is not exactly stretching the envelope when you think Audi have a 2.0L single turbo unit producing 270hp and both the EVO and Imperza comfortable produce well in excess of 300hp. To put it in perspective, to match the TT/S is produce per litre, the 335i should be pushing 405hp. See where I am coming from. What BMW went for with the 335i engine was the easy route, large capacity, two turbos and modest output per litre. One would expect very little lag, one would expect a large capacity engine feel, but for BMW to take the FI route for the next M3/5/6 would require a lot more thought than has been done here. The capacity will have to reduce compared to the previous engines and the desired output would need to be closer to 140hp/L to maintain the desired weight including turbo/piping etc and yet still delivery the feel of a large capacity engine and still crave revs, this is when BMW's engineering skill will be tested, far more than anything they have done in the past. Because this time it's their reputation on the line. |
08-03-2008, 03:40 AM | #18 |
Rep 5,448
its the end of the world as we know it.....
the next M3 will have 0,9 liters and 55 hp.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
08-03-2008, 01:24 PM | #19 |
Rep 8,027
I know a hack of a lot of 335i guys like to pipe up about how quick their car is and to some extent it's comparable to the new M3.
Right I found this from Youtube, twins - one with a stock 335i and the other in a stock S4. You be the judge if you think the 335i is all that mighty in the face of the evidence. Personally my S5 would have walked an S4 and if you believe the BS that quattro drains power to the extent that TB believe then the 335i should have win easy, remember the 335i have been dynoed to produce a lot more than the quoted 306hp, it's more like 330hp. So lets say 330hp (rwd and 12% drivetrain lose) vs 344hp (awd and 25% draintrain lose) [u2b]FX6hTiLnGII&feature=related[/u2b] |
08-03-2008, 01:47 PM | #20 |
1549
Rep 6,754
Great, we didn't have enough 335i bragging lately.
Best regards, south
08-04-2008, 04:00 PM | #21 | |
Rep 2,244
When talking about power per liter, BMW has demonstrated they are capable of being at the head of the game. The comment that their reputation is on the line this time does not make any sense to me. The reputation of any quality company is on the line with every product and service they offer throughout their history, not just at certain times to certain individuals. |
08-05-2008, 02:29 AM | #22 | |||
Rep 8,027
Like I say there is a lot at stake. |
