04-25-2019, 05:05 PM | #1 |
Rep 10
PLEASE HELP! ECS Spacers causing vibration
Hey all,
I have a pair of 15mm spacers in the front and a pair of 20mm in the back. The look of the car is fantastic with the 20 inch wheels. The one problem I am having is I feel a vibration in my steering wheel and when I hit acceleration for take off the entire front end starts to vibrate and even felt in the passenger side. Any suggestions as what can be wrong? these are the spacers below https://www.ecstuning.com/b-ecs-part...003990ecs03kt/ https://www.ecstuning.com/b-ecs-part...003990ecs04kt/ |
04-25-2019, 05:18 PM | #2 | |
Rep 7,164
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
04-25-2019, 05:29 PM | #3 | |
Rep 10
Yes they came with the extended bolts. I hand screwed in the bolts and then torqued to 90. What is the correct torque amount you guys suggest? are the lugs what can be the only concern? |
04-25-2019, 05:48 PM | #4 | ||
Rep 7,164
04-25-2019, 06:08 PM | #5 |
Rep 10
04-25-2019, 06:44 PM | #6 | |
Rep 7,164
04-25-2019, 06:51 PM | #7 | |
Rep 535
I have H&R spacers and absolutely no issues. |
DaddyBus3.50 |
04-25-2019, 10:30 PM | #8 |
Rep 18,757
That's why I only sell H&R.
Got a few companies offering me their product or even private labeling, but I don't trust their quality and I don't want to risk you guys and my business. Making a spacer is not hard. Finding a good source of material are hard these days.
04-26-2019, 04:31 AM | #9 | |
Rep 118
04-26-2019, 09:43 AM | #10 |
Mmmmm…
1152
Rep 2,426
Drives: F15
Well the inside of the wheel rim and the rotor hub are both rough and together they fit together fine. Assuming the face of the rotor hubs are probably also kind of rusty, I would suggest cleaning the mating surfaces (both rotor side and rim side) then try again. First start with a rust remover on a rag, even a wire brush on the rotor side. The anodized finish of those spacers you posted wouldn't sit very well on a rough surface perhaps being just a little unevenly sitting can be a problem. Cleaning it would let it sit much closer. I'm pretty sure ECS would want you to do this before letting you exchange it (they have a reputation they need to hold as well).
2015 BMW X5 xDrive50i
BMW CCA 509766 |
r33_RGSport13053.00 |
04-26-2019, 09:58 AM | #11 |
Rep 401
I use a wire brush attachment on a drill to clean the hubs and rotor face every time I mount my wheels. I also coat the hubs and faces with Anti-seize. This prevents the surfaces from bonding to each other and becoming stuck, and it also sucks the spacers down tight to the hubs when you torque them down.
2015 BMW X5 35d Msport Carbon Black/Mocha Nappa 2013 Cadillac Escalade Platinum Diamond White Pearl/Cocoa 2007 BMW M6 Sapphire Black Metallic/Black 2005 Ninja 636 Lime Green |
04-26-2019, 10:00 AM | #12 | |
Rep 651
Expand your wheel options by dialing in fitment of 72.6mm centerbore wheels on your 74.1mm hub If that is what you have, they are not hubcentric fit to your stock F15 wheels. Edit: I have used ECS spacers in the past and they are good quality, but ECS is not always on top of what you actually need, like Ben (r33_RGSport) is. If you are using 74.1mm centerbore wheels on spacers made for 72.6mm centerbore wheels, it will explain your problem. You will either need to buy new spacers, or buy hubcentric rings. (Not sure if Ben sells the hubcentric rings or not). In my opinion, you are better off trying to sell the ECS spacers, and buy new correctly matched sets from Ben! Last edited by 1norseman; 04-26-2019 at 10:11 AM.. |
04-26-2019, 10:07 AM | #13 | |
Mmmmm…
1152
Rep 2,426
Drives: F15
BMW CCA 509766 Last edited by alphaod; 04-26-2019 at 10:21 AM.. Reason: Typo. |
04-26-2019, 10:50 AM | #14 | |
Rep 401
04-26-2019, 12:05 PM | #15 | |
Rep 1,061
04-26-2019, 01:31 PM | #16 |
Rep 401
I agree with you there. I use a couple of swipes just to prevent the spacer from bonding to the rotor surface. Not sure if you have every had this happen, but it can be a nightmare situation to get off.
04-26-2019, 01:42 PM | #17 |
Rep 530
Drives: 2020 BMW X5 MSport Arctic Grey
Having had spacers of some sort on almost every of my last 25 or so cars...I can say a few things:
1: hub centric is a must if at all possible. And I mean an exact fit. 2: Hub rings are ok, but if they are plastic they wear out and have to be replaced depending on how often they are on and off the car. 3: Quality of the spacer material/manufacture matters. Some are softer aluminum, and when they get torqued, or over torqued, or over torqued on one of the bolts, it can cause super small surface variances that are exaggerated when the wheel in spinning. 4: Wheel size, tire size, combined weight and size of the spacer all make a relative difference. See 1-3 above. I have had lots of brands, H&R, Ichiba, ECS, China direct, a few others I can't remember. Only go with top brand names and make sure they are not fakes, and this will reduce the issues. I have had a car that no matter what brand, what ever I did - there was always a vibration as long as a spacer was on. |
r33_RGSport13053.00 HJ478.00 |
04-26-2019, 08:46 PM | #18 |
Rep 2,995
Take the spacer and place on the hub. Is there any play?
Then take spacer and set it inside the wheel bore. Is there any play there? If no and no. Then you should be ok. |
04-26-2019, 09:03 PM | #19 | ||
Rep 18,757
04-27-2019, 11:12 AM | #20 | |
Rep 222
2. the OP gave us the part numbers of the spacers he bought 3. those spacers have an carside 74.1 diameter, wheelside 72.6 diameter 4. the OEM F15 wheels have a 74.1 diameter 5. therefore, there is 74.1 - 72.6 = 1.5mm gap between spacers and wheel 6. a gap allows the wheel to be offcenter, causing massive vibration 7. you bought the wrong spacers 8. return these, sell them, or trash them ... buy correct spacers |
04-27-2019, 02:42 PM | #21 | |
Rep 2,995
1norseman399.50 |
04-27-2019, 05:14 PM | #22 |
Rep 222
