05-21-2019, 01:59 PM | #1 |
Rep 231
Car unexpectedly sitting for six months - Advice needed
So I've ended up in a difficult situation. To keep a long story short I am currently in Europe and will be here for the next 6 months while my car is back home sitting in my condo garage.
My main question: Will the BMW LiFePO4 battery be fine when I get back after 6 months of not being used? If yes, that's great news! If no, then I need advice because a few months before I knew I would be leaving I actually took off the manual keyhole and replaced it with the IND keyhole cover. In other words, no power, no getting into my car!!! Idiot I know! I have 3 different options that I could think of: 1) Leave it "as is" and hope it's fine in a deep-sleep state until I get back. 2) I can have a friend open the doors to pop the hood essentially "waking-up" the car and turn back on my LiFePO trickle charger once a month, but it may only run for a few hours at most. "Charging car batteries" is against my condo bylaws so the building staff will ALWAYS unplug it when they see it plugged in. Long story, don't ask. 3) I can have a friend start it and let it idle for ~1hr once a month (Driving is not an option, storage insurance). Idling will also get me in trouble with the condo board because "letting cars idle" in the parking garage is also not allowed, but I really don't care at this point. I'm just not sure if 1 hour of idling once a month is enough to actually charge the battery significantly or not? Any advice or other recommendations for the best course of action? I'd really hate to get home and have to smash a window just to be able to pop the hood and charge the battery, or worse have the battery completely dead and have to shell out $1500+ for a new one. |
05-21-2019, 02:27 PM | #2 |
202
Rep 167
You would probably be best having a friend checkup on it when possible making sure it keeps charge. By the way you would not have to smash window to pop open hood. Just pull key out of the fob and unlock the door manually.
05-21-2019, 02:30 PM | #3 |
///Multiple
2993
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
This is hindsight, but given your condo's restrictive rules regarding cars, your best bet would have been to put it in storage somewhere else where you could plug in a trickle charger.
I know you said that you insurance would prevent your friend from driving it, but is there any way that this could still be done? Are you allowed any time for a trip home where you could take care of this yourself? Three months might be OK, but I doubt six months would be.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
papasmurf_m3454.50 ando2005.00 |
05-21-2019, 02:32 PM | #4 | |
///Multiple
2993
Rep 4,243
Justin@autocouture202.00 |
05-21-2019, 03:13 PM | #6 |
Rep 23
I left mine for 2 months after i moved house and got loads of error codes which is apparently a sign of low battery, a few drives later and they went away.
This thread may be of interest to you: https://f80.bimmerpost.com/forums/sh....php?t=1487492 |
05-21-2019, 03:19 PM | #7 | |
Rep 231
So I guess I need help now to determine how much "charging" will be enough to limp the battery along? A couple hours (hopefully) on a trickle charger once a month? or Letting it idle for an hour a month? (Keep in mind I only have 2/3 of a tank of gas). |
05-22-2019, 07:21 AM | #11 |
Rep 6,125
What about the fuel?
Wouldn't you need stabilizer?
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
05-22-2019, 07:44 AM | #12 |
Rep 224
BMW connect will email you if the battery gets low! mine did after the car itself managed to leave the headlights on all night. Then get your friend to plug the trickle charger in (if its been unplugged)
05-22-2019, 07:46 AM | #13 |
Rep 231
Great idea guys to have him pull the battery and leave it trickle charging on a workbench! Gonna try to sort that out. Although now I'm really kicking myself for not just doing that from the start.
Since he's never worked on a BMW before and I've never actually taken out the battery (just disconnected it), is it as simple as undoing a couple of bolts and pulling it out? Step 1 is to have him replace the IND keyhole cover with the factory one that has the manual key. Step 2 is having him fold down the backseats flat so that we can get access to the trunk later to reinstall the battery. Step 3 is pulling out the battery then manually locking the car doors. Am I missing anything??? |
05-22-2019, 07:49 AM | #14 |
Rep 231
I spoke with my local BMW service department before I left. They said it didn't require any sort of fuel additives. Just 1/2 to 2/3 tank of fresh gas before I left and to top-up with fresh gas when I get home and to drive conservatively for that entire tank.
Then again they also said the battery would be fine the entire time and I was the one to insist on buying a trickle charger from them so....... |
05-22-2019, 08:49 AM | #15 | |
Assistant TO the Regional Manager
617
Rep 728
As for fuel, my motorcycle just sat for 6 months with a full tank of fresh fuel. Had absolutely no ethanol issues to speak of. You should be just fine. |
05-22-2019, 11:02 AM | #17 |
Rep 1,977
1. Remove battery and trickle charge on work bench.
2. Have your friend either early morning or late evening drive your car around inside the garage for a bit. I know it’s not ideal but at least it’s not on public roads and during those early morning or late evening times, not much action should be occurring in the garage. 3. He could always take a 5 gallon jug when you do go low in gas. One more thing, you may want tire cradles to save your car from flat spots. Or your friend can just drive it around. See #2. |
05-22-2019, 02:11 PM | #18 | |
Rep 231
I filled them up to the max listed 60psi before I left, but since someone will be there anyways I can have them drive it back & forth a bit. |
05-23-2019, 03:48 PM | #21 |
Rep 231
Thanks for all the recommendations.
As an update: I had a friend do a recon mission for me today & learned that my condo parkade is dusty AF! Car was spotless and clean before I left. It's breaks my heart to see such a beautiful machine sitting like this. I'm sorry fellow Bimmerposters for such neglect! Don't worry I plan to make up for it with some track days and auto-cross sessions when I get back though! |
05-23-2019, 03:56 PM | #22 |
Rep 885
you behave and serve 75% of your sentence so more like 4 months.
SAFE-GUARD tire/wheel/windshield/paint protection is a FRAUD! do not waste your money!
