06-10-2019, 02:04 PM | #1 |
BimmerPost Supporting Vendor
2872
Rep 11,374
Future Classic -E9X M3 / E82 1M Motorsport Hub Retrofit Kit
The E9X M3 / E82 1M have unquestionably become modern-day icons for their formidable street and track dominance. Both of these cars are equipped with M12x1.5 hardware from the factory, leaving them precariously prone to failure during rigorous track sessions and consequently, a potentially dangerous and damaging fate.
Fortunately, Future Classic has spawned a comprehensive motorsport-worthy hub retrofit kit using a blend of OEM BMW components from the F8X M3 / M4 and parts of our own creation. These new hubs will not only convert your E9X M3 / E82 1M to robust M14x1.25 hardware, but it will also shave valuable rotational mass from each corner. OE M12x1.5 Front Hub Assembly: 3293g FC M14x1.25 Front Hub Assembly: 2957g (-0.74lbs per corner) OE M12x1.5 Rear Hub Spindle: 1686g FC M14x1.25 Rear Hub Spindle: 1441g (-0.54lbs per corner) Each hub kit comes pre-assembled, moly-coated, and includes everything you'll need for a truly plug and play retrofit, including all new hardware. This kit may also be optioned with our highly coveted 75mm or 90mm race studs, making its a truly complete solution for track enthusiasts looking for a competitive edge. What is moly coating? Molybdenum Disulfide Coatings (MoS2 coatings), also known as Moly Coatings, are a dry film lubricant that are commonly used in applications where load carrying capacity, operating pressure and coefficient of friction are primary concerns. This coating provides effective lubrication in a wide range of loads, in many cases exceeding 250,000 psi. Moly coatings lubricate sacrificially by transferring lubricant between the two mating surfaces, which helps to reduce wear and coefficient of friction. https://ind-distribution.com/product...b-retrofit-kit Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
06-10-2019, 03:15 PM | #3 |
Rep 1,881
Do the brake rotors need to be modified to fit over the 14mm studs? i noticed in the video you guys were drilling the holes out on the Alcon rotor hats.
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
06-12-2019, 11:15 AM | #4 | |
2872
Rep 11,374
It depends on the brake kit. When running the Brembo BBK there is no need for drilling. On factory disc you will need to drill to accommodate the new studs. FC will be adding an option to include the required drill bit on the kit.
06-12-2019, 11:20 AM | #5 | |
///M Powered for Life
11500
Rep 10,333
I only did the fronts as those are the ones with the most risk |
