06-20-2019, 12:13 PM | #5 |
Rep 2,145
Drives: 2011 E92 M3
Soooooo true. Getting a virgin belt on the Dinan pulley must be such a PITA since getting the belt on with 30,000KM on it still suuuuked.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
06-20-2019, 12:44 PM | #6 |
BimmerPost Supporting Vendor
2945
Rep 21,756
I have the Macht Schnell pulley sets and have been really happy with them. Macht Schnell is the only one with both the crank pulley and power steering pulley set. Could tell a difference right away after I installed them. Not to mention easiest to install.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
chief208.00 |
06-22-2019, 11:21 AM | #9 |
Rep 207
I say, it would free up perceivable power but not sure if you want the water pump to be under driven, especially if you track the car.
Maybe get a larger/upgraded radiator first... |
06-22-2019, 11:37 AM | #10 |
Rep 2,145
Drives: 2011 E92 M3
At 7000 RPM, an under-driven water pump will make allllll of the flows you will need.
06-23-2019, 05:29 AM | #12 |
Rep 303
Bought a used MS pulley and installed it when I had some maintenance done. Car seems to rev a little faster but that's it. Dont expect much but it's worth it at used prices.
06-23-2019, 06:54 PM | #13 |
Rep 4,180
I spend a lot of time in traffic (low rpm) in hot weather. Would underdrive pulleys affect my air conditioning, or make the power steering work harder at low rpms?
06-25-2019, 03:11 PM | #14 |
Rep 142
I did mine and an aFe power intake, the two combine help open up 20 horse puppies! It was worth it to me to do it, plus gained approx 2-2.5 MPG when cruising on the hwy for long distance as a side benefit.
http://www.superstreetonline.com/how...ke-charge-kit/
-Kai
