06-21-2019, 05:33 PM | #1 |
Rep 48
Over heated front brakes
Had my car at the track today and was pushing pretty hard when I got no pedal feel going into a turn. Got off the track and the front passenger rotor just had pad material smeared all over it and I think maybe a small fire. bubbled off the paint on the caliper and melted my caliper pin covers and the piston boot. all other rotors/pads looked fine for track use, no broken brake lines or fluid drop on the master. Any ideas what might have happened here and what I should be taking a look at?
Running PFC 08 pads all around, Stock rotors, Motul 600 fluid. https://photos.app.goo.gl/yCyvVsCiALGL2paHA https://photos.app.goo.gl/UW9Ce24fYpzHPBDL7 https://drive.google.com/file/d/1-1S...ew?usp=sharing[ Last edited by coneill; 06-21-2019 at 05:34 PM.. Reason: Images not showing |
06-21-2019, 05:40 PM | #2 |
Rep 12,736
They got too hot. Fluid is shot and start thinking about a bbk if you're going to keep doing this. Once the boots go, crap gets in there and accelerates wear on the caliper.
Problem is the oem rotors can't get rid of heat, so even if you have great pads, the rotors don't do their job well.
Instagram; @roastbeefmike
coneill8.50 |
06-21-2019, 07:21 PM | #4 |
Rep 12,736
Ap racing or pfc.
06-21-2019, 10:52 PM | #7 |
Rep 12,736
Mdm uses the front brakes most of the time. It's a big contributing factor.
06-22-2019, 10:17 AM | #8 |
Rep 48
06-22-2019, 10:34 AM | #9 |
Rep 12,736
No adjustment. Mdm off is the only way. I still track with mdm on, by the way. My ap racing kit can take it, but I have excessive pad consumption.
06-24-2019, 12:01 PM | #11 |
Stop the hate, get a V8
3853
Rep 8,625
You can run with MDM on, and the stock brake setup, but you will just need to learn how to manage the brakes for a given track and conditions. That will mean some coasting and driving at 7/10ths versus 9 or 10/10ths.
Past: 2011.5 M3 sedan ZCP |
06-24-2019, 03:07 PM | #12 | |
Rep 1,503
2011.5 E90 M3 DCT ZCP Slicktop
06-24-2019, 03:23 PM | #13 |
1951
Rep 1,909
Drives: E92 M3
Both, if anything. I went with Zimmermann branded version of the rotors and they're holding up a lot better than the GenuineBMW version, even though they should be "exactly the same." You can tell you've overheated your rotors when you start hearing a pinging or ticking noise from them. When that happens, pad deposits are likely.
coneill8.50 |
06-24-2019, 03:33 PM | #14 | |
1951
Rep 1,909
Drives: E92 M3
06-24-2019, 03:39 PM | #15 | ||
Rep 12,736
Caliper's job is to hold the pads and be rigid. Rotor's sole job is to convert energy via heat exchange.
06-24-2019, 03:41 PM | #16 |
Rep 5,482
The OEM rotors suck out loud compared to aftermarket rotors as air pumps - partially obstructed air path, not enough vanes, oddly shaped inlet, semi-floating rather than full floating
That said, I've seen people make them work, ducting the everloving crap out of them with good pads and fluid, on racecars like SCCA Touring that require a weight penalty for brake upgrades or whatnot. Glowing discs lap after lap at full tilt for 40 minutes at road america is about as good a torture test as you'll get and I talked to them afterward and they seemed like they got it to work ok
06-25-2019, 12:28 PM | #17 | |||
Rep 1,503
06-25-2019, 12:50 PM | #18 | ||||
Rep 12,736
The rotor surface is designed to exchange friction into heat and dissipate it into the cooling vanes between the rotor faces where it is cooled by air. This also keeps heat out of the hats (because less heat soaks in to the hats) and helps with keeping some other components exposed to less heat. Retrofitting a larger caliper/pad on to an oem rotor simply gives the oem rotor more heat, which it's already not very efficient in dissipating.
Bimmer Barney1251.00 coneill8.50 |
06-25-2019, 01:23 PM | #19 | |
3853
Rep 8,625
The pinging/ticking noise is just the sound of them expanding and contracting, as they are supposed to. Any car with a two-piece design will do this when pushed hard. I always heard it on my M3 when pulling off track and nothing bad ever came of it.
06-25-2019, 06:19 PM | #20 |
Rep 48
I took apart the caliper when I got home completey and it seemed to be in good shape. was able to push it back easily Wasn't hung or sticking. The bore was fine and even the piston had only some minimal wear on it. Cleaned it up and put everything back together. There is a decent amount of pad transfer on the other side as well. I think I might've just finally hit the limits of what the stock brake setup can take.
06-25-2019, 08:26 PM | #21 | |
1951
Rep 1,909
Drives: E92 M3
But I think the noise is an indicator you're starting to overheat the rotors. Perhaps there's some function that will give us the "too hot" temperature based on number of pings and ticks like there is for cricket chirps, but unfortunately rhyary has a different brake setup so there isn't an abundance of accurate data collected on the matter. |
06-26-2019, 07:10 PM | #22 | |
3853
Rep 8,625
Buy thermographic paint and put it on the vanes.
