06-29-2019, 05:28 AM | #1 |
Rep 10
Coilovers vs BBK.....
Hello all!
Im finally starting the street/track build on my e92 m3, and first my first "mod" is a set of apex wheels (18x10 square setup) and now i'm looking at my next mod; either kw clubsport coilovers or the pfc z54 front bbk. Just looking for some insight as to which of the two mods you guys would do first and why (one mod will be done this summer, the other I will tackle this winter). Thanks! |
06-29-2019, 07:29 AM | #2 |
Rep 12,736
You'll be nursing the brakes because you'll be faster with coilovers.
With brakes, you'll be able to develop further as a driver because you remove the variable oem brakes. Tracking on oem suspension also forces you to be smooth to progress.
Instagram; @roastbeefmike
06-29-2019, 08:09 AM | #3 |
Rep 1,036
I'd do the coilovers first and do pads and fluid if possible before making the jump to BBK
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
Bartledoo2691.50 M3ANMACHINE933.00 |
06-29-2019, 08:24 AM | #4 |
Rep 62
I'd go bbk but probably essex ap racing bbk simply because of the amount of different brands of pads you can use.
like a boss
jritt@essex1029.00 |
06-29-2019, 04:20 PM | #5 |
Stop the hate, get a V8
3853
Rep 8,625
Brakes, 100%. It will let you extract even more from the suspension you have. Plus it's a safety item.
Nice choice on the PFC, that kit is fucking amazing. Your next mod should be coaching and driver development (including telemetry). Again, it will let you extract more from what you already have.
Past: 2011.5 M3 sedan ZCP |
ptg704420.00 SYT_Shadow11500.00 |
06-30-2019, 10:48 AM | #8 |
Rep 1,694
if your serious about tracking you will want camber plates, the cost of labour to install and align is similar to coilovers. Therefore if you plan coilovers anyway, it makes sense just to do it in one. You can be fast on stock suspension, but I found it very frustrating given how soft it is. Coilovers made the car feel significantly more enjoyable to drive.
The stock brakes with proper pads and fluid really are not bad at all. I'm currently running PFC-11 pads with SRF fluid on RE-71r tires and have not experienced any fade for 20 minute sessions. However it depends if you are running tracks that are hard on brakes or not. I will get a BBK at some point but it really isn't nescessary in the beginning. I would just run the car stock with pads / fluid at first then decide what you feel needs improving, rather than thinking you need upgrades. It depends on your level of track experience as to how quickly you will out grow it. |
dparm3852.50 |
06-30-2019, 11:10 PM | #9 |
Rep 9,034
I'd check here for some used BBK.
I prefer to get new coilovers because you never know how much they've been used. This is another option for coilovers. It's a revalved Ohlin R&T coilover. You can get stiffer springs too. http://info.3dmmotorsport.com/bmw-e9...s-buyers-guide .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
ptg704420.00 |
07-04-2019, 07:47 AM | #11 |
Rep 1,325
I think it depends on where you are at as a driver. A lot of people bash OEM brakes , but with race pads and proper brake fluid it is quite capable for a majority of people out there.
If you have maximized both the OEM brakes and suspension then I would go for brakes. I believe there is *some* cost savings in the long term associated with that. (or at least I keep trying myself that). But before all that I would do camber plates like someokeentioned before
tdott3956.00 |
07-05-2019, 10:18 AM | #12 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
I would definitely choose coilovers first. The factory brakes with upgraded pads, lines and fluid will be sufficient for intermediate track use. The coilovers simply provide more driving enjoyment and will help you save your tires since you can add camber.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
07-05-2019, 11:35 AM | #13 |
Rep 1,570
Drives: 2013 LRP M3 Coupe
where do you spend more time? on the street or the track? coilovers are probably going to make your street driving less enjoyable if your roads are less than perfect. Brakes on the other hand will be a bonus for both.
07-05-2019, 04:38 PM | #14 | |
Derbo Tuning
3612
Rep 3,026
Thats the way I went!
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
Bartledoo2691.50 |
07-05-2019, 05:39 PM | #15 |
Rep 6,734
I would argue the opposite. Brakes will have zero discernible difference on the street. A quality coilover will be adjustable and allow for comfort on the street.
'23 X7
07-05-2019, 10:31 PM | #16 |
Rep 1,570
well then taking your argument.. a quality coilover will be adjustable and have zero discernible difference on the street.
07-06-2019, 09:20 AM | #17 | |
Rep 6,734
A BBK does nothing for stopping distance or braking performance on the street. You literally can't feel a shred of difference (assuming same pads and fluid). It provides fade resistance and more consistent performance when pushed to temperatures seen in a track environment.
'23 X7
07-06-2019, 12:04 PM | #18 |
Driver
2692
Rep 2,714
It probably depends on which tracks you will spend the most time, and the grip level you'll be running. With RS4 tires I'm fine with PFC08 pads on stock calipers/rotors and SRF fluid at my primary track. Haven't done a full hour session yet but I think they would be fine.
I went coilover first because I needed camber plates anyways, I wanted to learn on a vehicle that has somewhat consistent dynamics, a few events later I would want coilovers, and I knew I'd be doing this every week.
E90M 6MT Slicktop Single Humper in need of a diet
slicer2745.50 |
07-11-2019, 02:53 PM | #19 | |
Rep 842
Our widest CP9668 front setup that uses 25mm thick pads fits behind Apex Arc 8's without a spacer. Apex's sales manager actually just installed our CP9668 kit on his personal car. Tons of customer feedback on our kits on our blog. Feel free to contact us at any time with questions. |
08-07-2019, 05:23 AM | #20 |
Rep 1,231
Coilovers for sure. They make the biggest difference out of every 'go fast' mod I've done. Ohlins are light years ahead of the stock suspension and are still very comfortable. The difference in grip and being able to keep traction over uneven pavement is incredible.
08-07-2019, 06:05 AM | #21 | |
///M Powered for Life
11500
Rep 10,333
Get the PFC Z54, it's an incredible kit. I have two of them. And an AP RadiCal. Soft suspension forces you to be smoother with your inputs and teaches skills which are needed if you will ever be fast. Nursing the brakes however doesn't teach you anything. Being able to brake very late consistently is a big advantage, besides, using the 28mm thick pads is a big consumable cost difference the stock rotors. |
08-07-2019, 09:29 AM | #22 |
Rep 5,482
Some very fast racecars are "too soft" according to The Internet. Stiff springs don't necessarily make a car go faster or handle better - they certainly can help, but lower and stiffer is not an end in itself, you have to ask what you're trying to accomplish
BBK all the way for a car that's going to see a lot of track time, the savings in brake parts will pay for that coilover setup in a year Also, no matter which you decide to buy first, spend the extra $200 and duct the front brakes properly It comes down to this: Do you want to feel a bigger difference in the car, or get more consistent track time? If a) pick the coilovers, if b) do the brakes Also, replacing perfectly good stock brake lines if you stick with the storck brakes is a great way to introduce air into the system and not much else. Just do pads and fluid if you stick to the stock system, the BBK youe ventually buy will come with new lines anyway Also also, it's possible to ruin a car and want to sell it because it becomes too hardcore for street use. And by possible, I mean I see it happen to people all the time. If you're truly going to dual-duty this car, think carefully about how much spring you put on it. You might be better served doing a different damper setup altogether, with softer springs than most of the "BECAUSE RACECAR" full coilover kits come with, and get 99% of the performance Also also also, consider adding a front bar instead of coilovers for your next suspension mod. Pairs nicely with a square setup and gives you some balance adjustability without the full-special of a coilover setup while you're learning the car.
