07-10-2019, 09:51 AM | #1 |
DAK 2014 X5
Rep 11
Oil Pan Stripped?
I went to change the oil on my F15 today and noticed that my plug on the bottom of the pan is spinning freely. Thinking that I might not be able to plug the pan if I took it out, I stopped and thought I would see what the fix is for this. Can anyone point me in the right direction? New plug? New pan? Re-tapped pan?
Thanks. |
07-10-2019, 10:53 AM | #2 |
Rep 174
https://www.coxhardware.com/p-1972-o...iABEgLVT_D_BwE
Here's one solution. It depends on whether it can be retapped or you must use an over sized plug. Google is your friend and how you feel about repair. Most expensive is oil pan replacement. |
07-10-2019, 02:12 PM | #4 |
Rep 5,066
I personally overtighten everything. I think its just human nature to want everything to be super tight and secured….
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
07-10-2019, 02:21 PM | #5 |
<3 Flat Four
217
Rep 754
07-10-2019, 07:52 PM | #6 | |
Rep 7,164
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
07-11-2019, 09:01 AM | #7 |
Mmmmm…
1152
Rep 2,426
Drives: F15
Cheap option is helicoil of some kind. The problem is I would concerned about metal on the bottom of the pan due to the stripped screw
Expensive option is new bottom pan cover. I think it costs like $300 total for new pan plus new gasket and new bolts. I stripped mine somehow when I did my break in change at around 1200 mi; second change at 5000 mile found the screw was stuck. I did the pan replacement choice; on the stripped pan I found that there was a bunch of metal from the threads just barely still attached; re-tapping might have made it loose. Perhaps the correct step is you plan to first re-tap, remove the pan anyways to inspect the inside, then spend the extra for a new gasket and bolts. Worse case is you removed the pant and you decide for a new one instead of re-tapping.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
07-11-2019, 10:19 AM | #8 | |
Rep 2,995
07-11-2019, 10:54 AM | #9 |
Rep 7,164
You may be able to lightly tap in a slightly larger hex head into the screw then just replace with the correct size. Not sure how soft the metal is but given it strips so easy I but you could semi easily just tap in maybe the next imperial size up. I would try that first.
07-11-2019, 03:38 PM | #10 |
Mmmmm…
1152
Rep 2,426
Drives: F15
First time, yes I did. Now I only do it by hand and I finish it off with a torque wrench.
I learned my lesson the hard way.
BMW CCA 509766 |
07-11-2019, 05:17 PM | #11 |
Rep 2,995
Wow. At least you're able to admit it. But I'm generally curious, did you think the bolt had to be that tight? Or too lazy to remove one bolt by hand? I always thought it was a joke hearing people using an impact on a oil drain bolt.
07-12-2019, 09:05 AM | #12 | |
Mmmmm…
1152
Rep 2,426
Drives: F15
And the reason it stripped isn’t because it was on there too tight. It was stripped before it was screwed in slightly off angle.
BMW CCA 509766 |
Maverik2594146.00 |
