07-11-2019, 01:35 PM | #1 |
Rep 855
M2C competition brakes on F80m3/F82m4
HI Guys,
Has anyone replaced the stock brakes with the M2C calipers and larger rotors on a F80 M3/M4? Is it a direct bolt on to the stock steering knuckle? Do you need the different brake booster as well? (the one used with cars with the CCB option)? Thanks, Steve |
07-11-2019, 03:40 PM | #2 | |
Rep 464
Instagram:catpupu_f80 |
07-12-2019, 01:24 AM | #4 |
Rep 2,164
Interesting, I thought the different CCB brake booster was necessary because of the larger calipers and not because of the friction differences between iron and carbon ceramics.
07-18-2019, 05:25 PM | #6 | |
Rep 4,499
Thanks in advance!
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
07-18-2019, 06:51 PM | #7 |
Rep 28
Just installed in my M4 F82.
I have installed new CCB brake calipers (yellow), M2C brake discs, Endless ME22 brake pads, metal hoses and racing brake fluid. I have also coded the calibration of the M2C brake booster with 2NH. Great improvement. |
07-18-2019, 07:18 PM | #8 | |
Rep 855
not sure what N2H means, can you elaborate? |
07-18-2019, 07:22 PM | #9 | |
Rep 855
I don't see very many pad options for the calipers though aside from OEM |
07-21-2019, 11:45 PM | #12 | |
Rep 3,670
I run a Brembo GT kit and assume the pedal feel is similar to this kit. It’s more linear and predictable. The more you put down the more it will bite, and so forth |
07-22-2019, 04:29 AM | #13 |
Rep 386
Guys, sorry to ask but I cannot get the M2 Comp 400mm OEM part numbers for the discs front & rear?
just purchased a set of CCD calipers to upgrade onto my M4 Comp. any help greatly appreciated, Regards, Jamie
BMW E36 M3 Track car, Safety Devices role cage, Recaro Pole position seats, Bilstien Suspension, BBK, Poly bushed.(in factory white).
BMW F10 M5 Dailey driver. |
07-22-2019, 06:53 AM | #15 | |
Rep 386
regards, Jamie
behindthen0thing839.50 |
07-22-2019, 09:47 AM | #16 |
Rep 855
Front:
34118745793 caliper left 34118745794 caliper right 34118058655 dust shield left 34118058656 dust shield right 34118072017 brake disc left 34118072018 brake disc right 34116862801 (2) expansion spring 34116850934 (2) guide pin 34111123072 (4) hex bolt holding rotor to hub 34356792289 wear sensor 34116780509 (2) ventilation cap 34116780508 (2) dust cap Rear: 34218745797 caliper left 34218745798 caliper right 34118072019 brake disc left 34118072020 brake disc right 34216857151 (2) expansion spring 34218046255 (2) guide pin 34211161806 (4) hex bolt holding rotor to hub 34352284656 wear sensor 34116780509 ventilation cap 34116780508 dust cap |
07-26-2019, 01:27 AM | #17 | |
Rep 1,262
Drives: BMW 1M
07-30-2019, 05:59 PM | #18 |
Rep 855
for the gold calipers which anti rattle spring and guide bolts do you use?
is it these part numbers: 34116862801 (rattle clip/spring) 34116850934 (guide pin) This is of course using pads for iron rotors |
07-30-2019, 06:44 PM | #19 |
Rep 471
Interesting. Got any more pics of this setup? Any other modifications you had to make? I currently have carbon ceramics but have thought about doing something like this because Im frustrated with lack of wheel options. Not a fan of 20's.
07-31-2019, 10:52 AM | #20 |
Rep 374
very true ~ you really need to crank up that piston force on CCB kit.
What shall i buy for my next track toy
08-01-2019, 08:43 AM | #22 | |
Rep 73
did a track day last weekend with my 18" without a problem. note however, I use 380mm rotors. |
