07-28-2019, 10:03 AM | #1 |
Rep 1,915
Trunk problem
I experience a trunk problem whereby the tailgate does come down all the way, but not "rest" to the bottom. I can only make it "click" when I pull from the inside. I lubricated the latch liberally, to no avail.
The latch does seem to have "spring" in it. I even made it click using my fingers. Has anybody had the same problem? Worried it may be the soft closing mechanism, not providing enough force to click in. |
07-28-2019, 12:03 PM | #4 |
Living the dream
4588
Rep 2,194
Drives: X5 w/MPPK, MPE & RC GTS Black
No, I mean the lower section, the small tailgate that folds down. If it isn’t closed all the way, the lift-gate won’t close all the way. It may appear to be closed properly, but it may not be. I recommend opening it and closing it with some force.
P111591.50 |
07-28-2019, 01:20 PM | #5 |
Rep 535
If the lower one is not clicked in on both sides, this will happen. If there is something blocking on top, this will happen. Otherwise it may the soft close. What happens when you lightly close it - does it tighten itself?
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi |
07-28-2019, 02:00 PM | #6 | |
Rep 1,915
Will give it another try. |
07-28-2019, 02:01 PM | #7 |
Rep 1,915
I could not close it manually, from the outside; only from the inside.
07-28-2019, 02:52 PM | #9 |
Living the dream
4588
Rep 2,194
All good now?
07-28-2019, 03:04 PM | #10 |
Rep 1,915
Nope, either the latch needs replacement as it has lost its "spring", or, what I think is the worst case scenario, the soft-close mechanism has an issue.
It does seem to go down smoothly, and once it reaches the latch, it hangs a bit and can't close. Will have to take to it to mechanic to check it out. Will use manual close till then. |
07-28-2019, 03:59 PM | #11 |
Rep 560
The buffer stop or trunk guides may need some adjustment. I adjusted mine when the trunk occasionally wouldn't latch and now it is fine. However, unless you are good at this sort of thing, it might be better to have the dealer do it.
menelaos1226.00 |
07-28-2019, 05:43 PM | #12 | |
Rep 1,915
Will consult with a mechanic |
07-31-2019, 03:47 PM | #13 |
Rep 3
07-31-2019, 04:11 PM | #14 | |
Rep 1,915
None of them fixed the issue. I do however thank you very much as the tip made me start looking at all the other rubber pieces that make the soft closing mechanism work. Will provide an update on Monday when I visit the mechanic. |
09-25-2020, 06:38 PM | #16 |
Rep 1,915
10-18-2021, 04:05 PM | #17 | |
Rep 19
Our 2016 X5 has starting having issues with the trunk. The trunk will lower by all mechanisms (fob, button on the door, and button on the trunk itself) but will stop just short of latching without manual assistance. By manual assistance, I mean I wait until the trunk is almost closed and then I give it a hard push for the remaining few inches. It opens fine. It locks fine, once you get it closed. The lower gate is fully closed so I don't believe the gate position is the issue. I've seen different part numbers for the latch mechanism. Some are called lock latch and others are called lock actuator. Some are $150 and others are $400+. I'd love to get some idea of the correct part number before I start ordering. I've also heard the plastic trim on the gate can be a pain to remove without breaking clips so I'm really hoping to do this only once. |
10-19-2021, 09:40 AM | #19 | |
Rep 1,915
10-19-2021, 11:19 AM | #20 |
Rep 19
