08-08-2019, 02:45 PM | #1 |
Rep 53
Air suspension aftermarket replacement compressor options?
2015 X5 S Drive 35i ~90k miles.
Rear suspension is completely deflated - dealer is wanting north of $4k to replace the compressor and air bags, which just seems completely outrageous to me. I'm trying to gauge the feasibility of DIY with aftermarket parts. I'm finding lots and lots of posts about the airbags but not much about the compressor. I've been able to find the air bags aftermarket from Arnott but there are seemingly no aftermarket options as far as the compressor. I found a few listings on eBay but not certain if these are applicable to the 2015+ or not. So, can anybody point me toward an aftermarket compressor option? Secondly - is the BMW diagnostic software an absolute must when doing this job? Thanks in advance. |
08-08-2019, 03:39 PM | #2 | |
Rep 7,164
Drives: F90 M5 / F15 50i
You can also maybe see if you just need to replace the moisture beads. Maybe it's clogged. Dont get a lot of broken compressors on here. How many miles you got.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
08-08-2019, 03:50 PM | #3 | |
Rep 2,523
https://f15.bimmerpost.com/forums/sh....php?t=1511949 I don't think there is an aftermarket compressor, would be easier just to get used one off ebay, they sell for $300-400. |
MrBrooklyn7183.00 artem123251.50 Russmov1328.00 Twin Peaks94.00 kydiesel35166.00 XxBBVTMxX293.50 PnP206.50 |
08-08-2019, 04:33 PM | #4 |
Rep 1,270
The compressor got burned because he neglected to replace the airbags once they started to lose air... Is this proper maintenance? Obviously not!
Buy a car you can afford to maintain... |
08-08-2019, 04:46 PM | #5 |
Rep 317
Can you confirm that your air compressor is out you can pull out fuse #110 (trunk fuse box) and reinstall and hopefully reset the module. Also to note if there’s a significant air leak the air compressor will time out in 2-5 mins if it detects no pressure building.
08-08-2019, 05:03 PM | #6 | ||
Rep 317
08-08-2019, 05:48 PM | #7 | |||||||
Rep 7,164
There is a couple YouTube videos on how to replace it on an E70. It's the same product and process. Same for the airbags. All the same stuff. I would imagine changing the compressor isn't hard but you should be able to just pop the fuse to it and then unplug it from power and the two airlines and put the new one in. Fingers crossed of course. ISTA is necessary to do things like force the compressor on and to inflate the bags. Maybe it'll do it on its own when you put the fuse back in and put the car in "on". Can't say for sure.
08-08-2019, 05:49 PM | #8 | |
Rep 53
Hmmm, so I won't need ISTA to fill it? Is there any reason the new compressor wouldn't engage without going through the ISTA thing and get me me stuck in some sort of malfunction code limbo unable to fill the air bags? If I can be certain the compressor I need is part number 37206875177 (can anybody confirm?) then that's going to cost around $250 for either option of used OEM or aftermarket new with SWSD brand on Amazon. So, if I don't need ISTA, I can do this myself for around $500 taking a flyer on the aftermarket compressor. |
08-08-2019, 05:57 PM | #9 | |
Rep 53
Yes, my main worry is not being able to get the compressor to inflate the bags for some reason after replacement. I'll look around for that ISTA download. I'd assume I'd need an OBDII connector for the computer as well. |
08-08-2019, 06:26 PM | #10 | |||
Rep 2,523
https://f15.bimmerpost.com/forums/sh....php?t=1568962 Quote:
You're making opinionated assumptions too quick, and not helping anyone. |
08-09-2019, 09:18 AM | #11 | ||
Rep 53
08-09-2019, 10:15 AM | #12 |
Rep 2,523
08-18-2019, 05:28 PM | #13 |
Rep 53
Just to update this, I got this all finished up Saturday morning. Didn't even take me an hour and a half total.
I found a used OEM compressor on eBay for $225, and bought the Arnott spring set on Amazon for $258. I ended up doing this for under $500 total whereas BMW wanted $4,500.33. Literally saved four grand over the dealer. She also called around to a couple of "Euro specialist" shops who told her they couldn't find the parts except at a dealer which is just ridiculous. I'm sometimes amazed that shops are usually unwilling or unable to source parts outside of Autozone/PepBoys/O'Reillys or a dealership. Onto the pics. Not kidding, I literally just did this in a parking lot near where she parked her car and left it a week or so ago lol. It was almost undriveable in the bottomed out position and she'd have another 45 minute drive home so we just left it. I loaded up my little Civic with a crap ton of tools but ended up not needing anything except a panel clip remover, 8 and 10mm sockets and ratchet, a 10mm wrench, jack stands and a jack, and then a larger flat head screwdriver to pop the air bag tabs out. I did NOT end up needing ISTA at all. I just pulled the 40A fuse before I started, then when I was done I put the fuse back in. At this point, I wasn't sure how to try to make the compressor engage so we turned the ignition "ON" without starting the car and nothing. Locked the doors and unlocked them and opened the doors and still nothing. Started the car and still nothing. So I was starting to think crap I need to mess with ISTA, but then while the car was still running I just pulled the 40A fuse again and stuck it back in and then the compressor came on and instantly started lifting the back end. I also have to say the push-lock pre-installed fittings on the new Arnott bags is a really, really nice touch. Kudos to those guys. If I get some time, I'll dig into her original compressor a bit and see if I can figure out what exactly failed on it. Found a shade tree to work under and out of this hundred degree Texas heat : Air bags removed. Didn't look too bad but when I pulled the bags out to their fully expanded state I see some wear and guess they could very well be leaky: One of the Arnott's installed: Good as new: |
11
Russmov1328.00 thezarb14.00 Flee61561.50 1norseman399.50 Kraftwerk AG460.00 menelaos1226.00 BimmerTy195.50 Twin Peaks94.00 kydiesel35166.00 KRS_SN13698.00 FCX52409.00 |
08-18-2019, 06:41 PM | #14 | |
Rep 1,343
Drives: 2015 BMW X5 xDrive 35i
2015 BMW X5 xDrive 35i-Current
2016 BMW X4 xDrive 28i-Sold 2014 Lincoln MKX-Sold |
08-18-2019, 09:09 PM | #15 | |
Rep 22
08-19-2019, 12:42 PM | #18 | |
Rep 53
Yeah, I never see any EF's out and about any longer even though they used to be so ubiquitous especially with the "ricer" crowd back in my younger days. I do see an occasional CRX but that's it. If I couldn't do all my own work/fabrication I wouldn't be driving around a 30 year old car as a daily that's for sure. It's slow as molasses but it's super reliable and still gets good gas mileage. If I ever wreck it though it's going to take me a while to find replacement parts for it. I don't even see these in junkyards anymore. |
Russmov1328.00 |
08-21-2019, 10:24 PM | #19 |
Rep 7,164
Glad I could help. Would have loved to see a bit more pictures of the compressor swap and a DIY as you're the first I've seen. Only way to keep these forums strong.
08-23-2019, 05:34 PM | #20 |
Rep 53
I thought about it but once I got in there, there was literally nothing to it so I didn't much see the point to be honest. Just have to unplug a few (three I think?) wiring harnesses, pop off that rubber hose, unscrew the red and blue lines, and drop the compressor assembly/bracket which was just held in with three nuts. The hardest part is pulling off the splash shield and remembering which side the red and blue go to.
Maverik2594146.00 |
08-24-2019, 12:32 PM | #22 | |
Rep 7,164
