08-21-2019, 03:08 AM | #1 |
Rep 2,368
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Will my battery go flat in 2 months?
I had no time to grab a battery tender, so left the car as is. Will it go flat in 2 months?
Battery is an year old Bosch AGM (bla-95-l5).
Pass me if you can.
08-21-2019, 06:25 AM | #2 |
Rep 233
08-21-2019, 07:06 AM | #4 |
Rep 1,067
kinda a crapshoot being a couple months. It would be a good idea to put the charger on it overnight when you return before hitting the start button.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus |
08-22-2019, 08:56 PM | #6 |
Rep 586
2.5 mo is about as far it'll go assuming a reasonably fresh/new battery.
2013 E92 M3 (the weekend good weather car), 2018 Tesla Model 3 Performance (the 20k mi/yr beater)
08-22-2019, 09:44 PM | #7 |
Rep 875
I've let mine sit almost two months and it started, but it all depends on the state of the battery when you park it.
M3 - X5 - 911 - Miata - Raptor - Edge
08-22-2019, 09:54 PM | #8 |
Rep 498
Drives: 2010 E92 M3
I left my car in storage for 5 weeks. When I got back to it the car cranked up like I'd driven it yesterday.
I'm sure you have to consider variables like age of the battery and temperature in the garage but based on how easily my car started after 5 weeks I wouldn't rule out 8 weeks.
2010 E92 M3 // IG: @commuter_blue
08-22-2019, 11:43 PM | #9 |
Rep 234
Brand new or close to it, the battery should last 2months even with residual current draw, but it will be at its lowest AH/CCA rating. However if you can, it would be better to disconnect the neg or positive cable if you are unable to trickle charge it.
08-23-2019, 12:18 AM | #10 |
Driver
2692
Rep 2,714
I think I had mine sitting for like 5 months over winter with the battery still connected (forgot to disconnect) and it cranked fine. Still running that battery now! It is not a new battery either.
kyrix1st2373.50 |
08-23-2019, 04:51 AM | #11 |
Rep 24,863
Yes .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
09-24-2019, 01:28 AM | #13 |
Rep 2,368
Is anyone so anal as to pull the fuel fuse out and crank few times to get the oil pressure? Seems like a good idea for dry starts.
Pass me if you can.
10-16-2019, 11:00 PM | #14 |
Rep 2,368
**Update: The car started fine after 8 weeks! Looks like the car went into deep sleep mode while away.
Pass me if you can.
08-05-2020, 08:05 PM | #15 |
Rep 2,368
It's been 4 months since I last started my 6 speeder...will definitely charge overnight and pull the fuel relay out to get the oil pressure up.
For those of you tried, is it the fuse #70 for fuel relay?
Pass me if you can.
